Guys, been cleaning up my repair list, but can’t seem to make headway with this. Its been there for a while now.
I have looked through the logs, but don’t see anything obvious. Is there anything I should be searching for in the logs?
I am running HA on a Proxmox VM.
tom_l
June 12, 2023, 12:39am
2
Are you running HA Supervised or OS in the VM?
Home Assistant Supervised? It also has the OS (10.2).
tom_l
June 12, 2023, 1:38am
4
Supervised is extremely restricted. You can not run any other software.
# 0014. Installation method: Home Assistant Supervised
Date: 2020-06-03
## Status
Accepted
## Context
Define a supported installation method as per [ADR-0012](https://github.com/home-assistant/architecture/blob/master/adr/0012-define-supported-installation-method.md).
## Decision
This installation method provides the full Home Assistant experience on a regular operating system. This means, all components from the Home Assistant method are used, except for the Home Assistant Operating System. This system will run the Home Assistant Supervisor. The Supervisor is not just an application, it is a full appliance that manages the whole system. It will clean up, repair or reset settings to default if they no longer match expected values.
By not using the Home Assistant Operating System, the user is responsible for making sure that all required components are installed and maintained. Required components and their versions will change over time. Home Assistant Supervised is provided as-is as a foundation for community supported do-it-yourself solutions. We only accept bug reports for issues that have been reproduced on a freshly installed, fully updated Debian with no additional packages.
This method is considered advanced and should only be used if one is an expert in managing a Linux operating system, Docker and networking.
This file has been truncated. show original
francisp
(Francis)
June 12, 2023, 2:53am
5
Did you install some non-add-on Docker image ?
I didn’t think I was running any other software. I installed it via a script onto proxmox quite a while ago can quite recall the ins and outs now. Is running supervised on proxmox not supported?
Only the ones from the add on store.
francisp
(Francis)
June 12, 2023, 7:15am
8
According to your screenshot, you are not running supervised but HA OS. And it is difficult do install anything on HA OS
I install everything via the GUI. Add-ons, HACS, updates and so on. I thought that was ‘supervised’.
