Unsupported system - Connectivity check disabled error
Hello all and Happy Holidays to all
I am running Home assistant 2022.12.8, running inside docker on Debian 10 on an HP laptop
Since this update I am now receiving an error Unsupported system - Connectivity check disabled.
When I started my Home assistant adventure I decided to use home Assistant Supervised.
All was working fine now i get this error
What happened ? what did i miss?
Thank you for any help
in the mean time
Happy holidays to all and i wish you all; a better beginning
I’d check that you’re still complying with the requirements. It’s pretty common to see that people haven’t been keeping up to date with changes and have run into issues.
Thank you for the reply
however sorry i do not understand your comment. as i said it worked fine before and i only use that pc for home assistant. now i have this issue
The requirements change, they’re not set in stone. Versions of required software update, new required packages are added, etc.
You need to check and see if that’s happened and you didn’t update your system to keep it current.
Thank you for clarifying
All my system are updated every Saturday and they are current. My Debian pc was update and upgraded this morning bercause of the festivities tomorrow…
In this particular case both debian and the container was updated and upgraded.
this issue was happening last night and this morning . then i proceeded to perform the update following this i still received the error.
Many thank for your time
But… is it current with the requirements?
Sure, maybe your system was when you first installed Supervised, but time has passed since then. The requirements may have changed.
Supervised is fragile, if you don’t ensure you’re aware of changes to the requirements and keep your system updated to match then you’ll have issues like this.
hello
Happy new year
As a short answer to you question Yes
Thank you for your response
