I have debian 10 installed on my computer. On it docker and HA. For some time now I’ve been getting a message in HA:
System is unsupported because additional software outside the Home Assistant ecosystem has been detected. Use the link to learn more and how to fix this.
Please suggest how to fix this and make HA fully supported? Below is my docker list.
Debian 10 is unsupported, I think, so you need to update to Debian 11.
Look up the method on google. It is mostly a set of apt commands you need to run combined with a few restarts.
“Official support” is the support provided by the development team such as for Issues posted in Home Assistant’s GitHub repositories. I have seen Issues promptly closed for unsupported systems.
The development team determines what constitutes a supported/unsupported system. From what I have seen, it’s based on minimizing support issues. For example, some docker containers interfere/overlap with Supervisor’s operation (like Watchtower) so they are rejected. That’s just one reason that I am aware of and there are probably more.
Thank you for the explanation.
What confuse me is who provides support to whom
What I feel is, there is no official support at all. There is an official forum (official just because it lives under the official domain) and GitHub to report issues.
Forum is where support is provided by users, not by devs (mainly) - thus ‘not supported’ is meaningless here.
GitHub is to report issues not get any support. I understand that devs might reject some requests, but they do that also for fully supported platforms for the same reason.
I hope they do not reject legit issue reports just because a reporter is using a so-called not-supported platform.
FWIW, here are two examples of recent Issues closed because the system was unsupported. There are undoubtedly others but it’s a bit tricky to find them (searching for ‘unsupported’ produces many discussions about unsupported devices, etc).
Yeah, in the first case, I have no expertise if it couldn’t be helped by HA devs. But writing ‘Report your issue to Linux server’ doesn’t sound friendly. I would expect an attempt to help in how a user could add the required lib on his own.
We will see if there is a change to change the wording reported in the second issue.
Just to make it clear I understand that HA devs cannot support an infinite number of platforms and their combinations and respect that.
Trying to do bug hunting on a system in unknown state is nearly impossible and generally adviced against.
If you ever seen Windows’ Blue Screen Of Death, Amiga’s guru meditation, Linux’s kernel panic, then you have seen a system in an unknown state and how the developers of those system handle it.
Many times the system could actually keep running, but it is just unknown when and what the outcome might be, so they fail instantly instead to be sure the state is returned to a known one.
It’s not the developer’s responsibility to solve problems for unsupported systems. That’s the very meaning of “unsupported”.
In this particular case, the user was instructed to seek assistance from the author of the container they were using. The container was missing a required library and the container’s author ought to be informed of it.
