I filed a bug here:
But, there are no responses. Is there anything I can do to help with adding support for this device?
I filed a bug here:
You may have better luck looking at local tuya integration.
I’ve been able to get a number of unsupported devices working via local tuya
This is awesome! Thank you for the suggestion, I have installed local tuya, and was able to figure out the important for me device settings:
1 -> on/off
2 -> speed (integer values [0 - 100])
4 -> manual on/off
101 -> Timer on Hours Settings
102 -> Timer off Hours Settings
103 -> Time on Minutes Settings
104 -> Timer off Minutes Settings
108 -> Cycle on/off
109 -> Timer on/off
So, I configured my pump controller as a fan entity, and I can now control pond waterfall flow right through Home Assistant.
