I’m facing issues with a script. I tried to reduce it so that it will be easier to understand what’s going on so consider undeclared variables as declared in the script scope.
What I’m trying to do is create a script that makes a light transition between a set of colors. I want to detect when the user tries to set a different color on the light so that the script stops when that happens. All logs are fine, meaning that the new target color recovered from the light displays the same, but it doesn’t prevent the loop from exiting when comparing both values in the “until” section.
I’m not sure what’s happening. Is the until instruction code in the same scope as the sequence ? Do I need to do something special to compare both values in the “until” call ?
sequence:
- repeat:
sequence:
- variables:
# Next color index to change to.
i_next: >
{% set idx = 0 %}
{% if decrement %}
{% set idx = states(color_tracker) | int - 1 %}
{% if idx < 0 %}
{% set idx = color_count %}
{% endif %}
{% else %}
{% set idx = states(color_tracker) | int + 1 %}
{% if idx > color_count %}
{% set idx = 0 %}
{% endif %}
{% endif %}
{{ idx }}
color_rgb_next: '{{ color_rgbs[i_next] }}'
- service: light.turn_on
entity_id: "{{ lights_to_change }}"
rgb_color: "{{ color_rgb_next }}"
transition: "{{ transition_time }}"
- service: logbook.log
name: "Debug (target): "
message: "{{ color_rgb_next | join(', ') }}"
# The target color might differ from the command. Recover the target color of the light to compare against it later
- variables:
color_rgb_next: "{{ state_attr(lights_to_change[0], 'rgb_color') }}"
name: "Debug (new target): "
- delay: "{{ transition_time }}"
name: "Debug (current state): "
message: "{{ state_attr(lights_to_change[0], 'rgb_color') }}"
# This displays the same thing as the call above
name: "Debug (current target): "
message: "{{ color_rgb_next }}"
# Means the light target color has been changed elsewhere
until: "{{ not is_state_attr(lights_to_change[0], 'rgb_color', color_rgb_next) }}"
name: "Debug (current state after loop): "
