Hi. I have a problem with a single person that can’t access my Home Assistant from his smartphone, when using mobile data.
So…
- I don’t have any peculiar set up, no proxies or reverse proxies that I know of
- I can access just fine, from internal network and from external, from PCs and mobile phones and tablets
- this one person with the problem can also access fine from internal network (wi-fi)
- but when using mobile data to access the app (keeping the same URL) he sees “400 Bad request” on the screen
- and at that same time I see these errors in homeassistant.log:
ERROR (MainThread) [homeassistant.components.http.forwarded] Received X-Forwarded-For header from an untrusted proxy 213.30.118.108
- that IP address belongs to Vodafone which is the GSM operator he uses. The value is not completely static, but always seems to be in the range
213.30.118.*
I’ve seen configurations that supposedly solve this:
… but they don’t let me specify a range, only specific IP addresses…
But most importantly, I don’t think this should be happening at all ![:exclamation: :exclamation:](https://community.home-assistant.io/images/emoji/twitter/exclamation.png?v=12)
Can any kind soul please explain what is going on? Why would one phone get blocked? My own phone uses the same GSM provider and works fine…
