I have been attempting to implement the Light Component on my daughters bedroom lights (A length of WS2812 under the bed).
There are two forms of triggering for the lights… a PIR sensor and a zigbee 3 button via MQTT. Everything seems fine, except the code occasionally spits an error related to the light effects.
Here’s my code…
substitutions:
off_hour: '5'
on_hour: '14'
esp8266:
board: d1_mini
framework:
version: recommended
esphome:
status_led:
pin: GPIO2
# Enable logging
logger:
level: VERBOSE
# Enable Home Assistant API
api:
encryption:
key: <REDACTED>
ota:
password: "<REDACTED>"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Esp4-Bdrmlights Fallback Hotspot"
captive_portal:
mqtt:
broker: !secret mqtt_broker_new
username: !secret mqtt_login
password: !secret mqtt_passwd
port: 1883
reboot_timeout: 0s
keepalive: 60s
discovery: false
on_message:
- topic: zigbee2mqtt/Q-3Button-Remote/action
payload: '1_single'
qos: 0
then:
- if:
condition:
and:
# If the LED's are off
- light.is_off: bdrm_led_lights
then:
# Turn on the LED lights
- script.execute: rainbow_effect
- logger.log: "The LED lights are ON Rainbow"
- script.execute: turn_off
payload: '2_single'
qos: 0
then:
- if:
condition:
and:
then:
- script.execute: randomize_effect
- logger.log: "The LED lights are ON Random"
payload: '3_single'
qos: 0
then:
- if:
condition:
and:
then:
- script.execute: pulse_effect
- logger.log: "The LED lights are ON Pulse"
sun:
latitude: !secret latitude
longitude: !secret longitude
script:
- id: turn_off
mode: restart
then:
- delay: 90s
- light.turn_off:
transition_length: 7.5s
- logger.log: "LED lights are OFF"
- id: randomize_effect
then:
- light.turn_on:
brightness: 60%
effect: random
- logger.log: "LED lights are ON with random effect"
- id: rainbow_effect
then:
- light.turn_on:
brightness: 70%
effect: addressable_rainbow
- logger.log: "LED lights are ON with rainbow effect"
- id: pulse_effect
then:
- light.turn_on:
brightness: 70%
effect: pulse
- logger.log: "LED lights are ON with pulse effect"
- id: scan_effect
then:
- light.turn_on:
brightness: 70%
effect: addressable_scan
- logger.log: "LED lights are ON with scan effect"
binary_sensor:
- platform: gpio
pin: D5
name: "Bdrm PIR Sensor"
device_class: motion
on_press:
then:
- if:
condition:
and:
# If it's night time
- sun.is_below_horizon:
- lambda: |-
auto hour = id(my_time).now().hour;
return hour > 12 || hour < ${off_hour};
then:
#Turn on the LED lights
on_release:
time:
platform: sntp
servers: 192.168.0.1
timezone: !secret timezone
on_time:
- hours: ${off_hour}
minutes: 0
seconds: 0
then:
- light.turn_off:
light:
- platform: neopixelbus
variant: WS2812
pin: D1
num_leds: 54
type: GRB
name: "FastLED WS2812B Light"
default_transition_length: 7.5s
effects:
# Use default parameters:
- random:
- pulse:
- pulse:
transition_length:
on_length: 1s
off_length: 500ms
update_interval: 1.5s
- addressable_rainbow:
speed: 10
width: 50
- addressable_color_wipe:
name: "Color Wipe Effect"
colors:
- red: 10%
green: 90%
blue: 25%
num_leds: 5
- red: 35%
green: 15%
blue: 60%
num_leds: 1
add_led_interval: 100ms
reverse: false
- addressable_fireworks:
update_interval: 32ms
spark_probability: 10%
use_random_color: true
fade_out_rate: 120
- addressable_scan:
- addressable_scan:
move_interval: 100ms
scan_width: 5
- addressable_random_twinkle:
name: Random "Twinkle Effect"
twinkle_probability: 15%
progress_interval: 32ms
And here’s the error I receive…
[10:11:35][W][light:476]: 'FastLED WS2812B Light' - No such effect 'addressable_rainbow'
[10:11:35][D][light:036]: 'FastLED WS2812B Light' Setting:
[10:11:35][D][light:047]: State: ON
[10:11:35][D][light:051]: Brightness: 70%
[10:11:35][D][light:085]: Transition length: 7.5s
[10:11:35][D][main:927]: LED lights are ON with rainbow effect
[10:11:35][D][main:860]: The LED lights are ON Rainbow
No idea why I am seeing the… ‘FastLED WS2812B Light’ - No such effect ‘addressable_rainbow’ error? Especially when the random and pulse appear to work?
I am sure it’s something I am missing, and is probably something simple. Any feedback appreciated.
