The specification includes parameters for different timeouts. If the relay is triggered via the motion sensor, it switches off after 3 minutes. If I switch the relay via HomeAssistant, I would like to switch it on permanently or at least for several hours.
It seems that parameters 10 and 11 are there for just that purpose.
I’d like to set a timeout for these parameters, but HA doesn’t allows any input for parameter 10 and 11: Cfg_screen|564x500
Does anybody know why I cant set those parameters? I’m using the default ZWaveJS integration.
Additionally, the spec says the other TimeOut is triggered by BASIC_ON Command? How do I send this command? Is this the default command when I switch the device via HA? Or do I have to send it manually?
Good hint!
I just did a re-interview, unfortunately that didn’t change anything.
Tomorrow I will remove the device completely and include it again. Maybe that will help.
Sorry for the late reply, too much work at the moment
Today I tried to exclude and include the device but it seems too far away from my Aeotec stick (it’s in the basement) and I don’t know if ex/include works over the meshnet? Maybe I’ll take the stick outside and use the stick’s built-in function. But does that make a difference compared to the re-interview?
Here is the diagnostics file:[diagnostics](dpaste/v0APq (JSON)](dpaste/v0APq (JSON))
