Unzip Capabilities in Configurator (File Editor)
I upload using the File Editor plugin a compressed file then with ssh I make an unzip. So I can easily upload big quantity of files and folders without the use of a File Server. I think to add the unzip files function on Configurator would be a good idea.
hey carras,
Do you mind sharing how or what command you use to unzip in SSH? I have uploading a zip file into the file editor and into a subdirectory www to use the TileBoard addin but cannot find how to perform the extract.
in any of the SSH plugin navegate to the file then:
unzip NAME.zip
use .zip files if you don’t know better
Actually, what I’m trying to do right now is from Visual Studio Code add-on install the plugin (inside VS code) call “zip file explorer”.
So you better use Visual Studio Code anyways, it has more features.
With VS code you can Drag&Drop files! So no need to zip upload an unzip!
Perfect thank you
