UPB intergration is the goal …This is what I am trying to follow Universal Powerline Bus (UPB) - Home Assistant
Also trying to follow this guys experience
" BoboSD
Hi all, first post here. I just got the HA-Green and I have quite a bit of UPB. I used the Simply Automated UPB-PIM USB device and plugged it into the bottom USB port on the back of the HA Green unit.
I then uploaded the export from UPStart to the same directory as configuration.yaml
I set up the integration as follows:
Serial: /dev/ttyUSB0
File location: xxxxxx_2024JAN1.upe
Clicked on Finish and then was presented with all of my UPB devices. Assigned them to rooms and then created some test buttons on a test dashboard. All seems to work just fine."
So I have put the UPB .upe file into the Samba Z folder and have connected the PIM to the HA Green USB port but am stimied at this point. Of course I have Chase Home Lighting Latest.upe file
Cannot find a PIM address to use here http://homeassistant.local:8123/config/integrations/dashboard
You all are really appreciated for staying with my awkwardness. Thank YOU… Steve
