So this is only one-way, but it’s better than nothing. As a noobie to hass, this took a long time to figure out. I’m guessing the techniques here can be used in other ways as well.
Tools needed:
- upb-cli : https://github.com/DaAwesomeP/upb-cli
- home assistant
- upb_dim.sh (below)
- upstart export file
configuration.yaml:
input_slider:
light_office_ceiling:
min: 0
max: 100
step: 5
light_bedmaster_ceiling:
min: 0
max: 100
step: 5
automation:
- alias: light_setlevel
platform: state
entity_id:
- input_slider.light_bedmaster_ceiling
- input_slider.light_office_ceiling
service: shell_command.upb_dim
data_template:
value: '{{ trigger.entity_id }} {{ trigger.to_state.state | int }}'
shell_command:
upb_dim: '/opt/upb_scripts/upb_dim.sh {{ value }}'
upb_dim.sh:
#!/bin/bash
echo "$*" >> /tmp/upb_debug
# called with param like: input_slider.light_office_ceiling 30
ROOM=`echo $1 | awk -F. '{print $2}'|awk -F_ '{print $2}'`
LIGHT=`echo $1 | awk -F. '{print $2}'|awk -F_ '{print $3}'`
ID=`cat /opt/upb_scripts/upb.upe |grep ^3|grep -i $ROOM|grep -i $LIGHT | cut -d, -f2`
upb-cli -n 99 -i $ID -t device -c goto -l $2 --send -p /dev/ttyS1
Thanks to DaAwesomePA, @ih8gates, @farstreet and others who post constructive examples and help online.
