Hello all,
I am trying to upgrade from 0.112.4 to 0.113.1 but I am having issues. Logs says:
20-07-28 08:54:55 CRITICAL (MainThread) [supervisor.homeassistant] HomeAssistant update fails -> rollback!
Please help
Log:
Here are some entries from the log:
20-07-28 09:48:21 INFO (MainThread) [supervisor.homeassistant] Update Home Assistant to version 0.113.1
20-07-28 09:48:21 INFO (SyncWorker_2) [supervisor.docker.interface] Update image homeassistant/raspberrypi4-homeassistant:0.112.4 to homeassistant/raspberrypi4-homeassistant:0.113.1
20-07-28 09:48:21 INFO (SyncWorker_2) [supervisor.docker.interface] Pull image homeassistant/raspberrypi4-homeassistant tag 0.113.1.
20-07-28 09:48:23 INFO (SyncWorker_2) [supervisor.docker.interface] Stop homeassistant application
20-07-28 09:48:23 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API error: Received message 8:1000 is not str
20-07-28 09:48:23 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API connection is closed
20-07-28 09:48:32 INFO (SyncWorker_2) [supervisor.docker.interface] Clean homeassistant application
20-07-28 09:48:32 INFO (MainThread) [supervisor.homeassistant] Update pulse/client.config: /data/tmp/homeassistant_pulse
20-07-28 09:48:33 INFO (SyncWorker_7) [supervisor.docker.homeassistant] Start homeassistant homeassistant/raspberrypi4-homeassistant with version 0.113.1
20-07-28 09:48:53 INFO (MainThread) [supervisor.homeassistant] Home Assistant pip installation in progress
20-07-28 09:50:09 INFO (MainThread) [supervisor.homeassistant] Home Assistant pip installation done
20-07-28 10:00:13 WARNING (MainThread) [supervisor.homeassistant] Don't wait anymore of Home Assistant startup!
20-07-28 10:00:13 CRITICAL (MainThread) [supervisor.homeassistant] HomeAssistant update fails -> rollback!
20-07-28 10:00:13 INFO (MainThread) [supervisor.homeassistant] Update Home Assistant to version 0.112.4
20-07-28 10:00:13 INFO (SyncWorker_6) [supervisor.docker.interface] Update image homeassistant/raspberrypi4-homeassistant:0.113.1 to homeassistant/raspberrypi4-homeassistant:0.112.4
20-07-28 10:00:13 INFO (SyncWorker_6) [supervisor.docker.interface] Pull image homeassistant/raspberrypi4-homeassistant tag 0.112.4.
20-07-28 10:00:14 INFO (SyncWorker_6) [supervisor.docker.interface] Stop homeassistant application
20-07-28 10:00:18 INFO (SyncWorker_6) [supervisor.docker.interface] Clean homeassistant application
20-07-28 10:00:18 INFO (MainThread) [supervisor.homeassistant] Update pulse/client.config: /data/tmp/homeassistant_pulse
20-07-28 10:00:19 INFO (SyncWorker_1) [supervisor.docker.homeassistant] Start homeassistant homeassistant/raspberrypi4-homeassistant with version 0.112.4
20-07-28 10:00:34 INFO (MainThread) [supervisor.homeassistant] Home Assistant pip installation in progress
20-07-28 10:01:35 ERROR (MainThread) [supervisor.utils] Can't execute update while a task is in progress
20-07-28 10:02:06 INFO (MainThread) [supervisor.homeassistant] Home Assistant pip installation done
