I can’t update to the latest.
home-assistant.log:
File "/usr/src/homeassistant/homeassistant/components/hassio/update.py", line 299, in async_install
await async_update_core(self.hass, version=version, backup=backup)
File "/usr/src/homeassistant/homeassistant/components/hassio/handler.py", line 45, in _wrapper
raise HassioAPIError(data["message"])
homeassistant.components.hassio.handler.HassioAPIError: Unknown error, see supervisor
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 200, in handle_call_service
await hass.services.async_call(
File "/usr/src/homeassistant/homeassistant/core.py", line 1738, in async_call
task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 1775, in _execute_service
await cast(Callable[[ServiceCall], Awaitable[None]], handler.job.target)(
File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 204, in handle_service
await service.entity_service_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 676, in entity_service_call
future.result() # pop exception if have
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 931, in async_request_call
await coro
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 713, in _handle_entity_call
await result
File "/usr/src/homeassistant/homeassistant/components/update/__init__.py", line 152, in async_install
await entity.async_install_with_progress(version, backup)
File "/usr/src/homeassistant/homeassistant/components/update/__init__.py", line 411, in async_install_with_progress
await self.async_install(version, backup)
File "/usr/src/homeassistant/homeassistant/components/hassio/update.py", line 301, in async_install
raise HomeAssistantError(
homeassistant.exceptions.HomeAssistantError: Error updating Home Assistant Core Unknown error, see supervisor
I had no trouble upgrading before this point.
the supervisor does warn “You are running an unsupported installation”, but I’ve always had been.
I’m running
Operating System : Ubuntu 18.04.6 LTS
Docker version: 20.10.17
I see the following warning in the supervisor log
22-09-23 12:00:09 WARNING (MainThread) [supervisor.resolution.evaluations.base] OS-Agent is not correctly working (more-info: https://www.home-assistant.io/more-info/unsupported/os_agent)
22-09-23 12:00:09 WARNING (MainThread) [supervisor.resolution.evaluations.base] NetworkManager is not correctly configured (more-info: https://www.home-assistant.io/more-info/unsupported/network_manager)
22-09-23 12:00:09 WARNING (MainThread) [supervisor.resolution.evaluations.base] Detected unsupported OS: Ubuntu 18.04.6 LTS (more-info: https://www.home-assistant.io/more-info/unsupported/os)
Is it because of my OS, and why the problem now?
, Thank you.
