Before the crash memory seems to go up. Cannot see why, but it might be a memory leak or so…
I’ve did a complete reinstall on a different SD card with restore. Problem is still there.
Funny thing is, the system seems not total stuck. If I leave it, sometimes, an hour later, you can turn on a light. But 2 minutes later it’s gone again. So it seems overly busy or so.
I’ve tried to downgrade the OS to 5.7 and 5.2, same problems.
Later today I’ll try to downgrade the core.
I wish the ppl in controll here would flag these OS/Core updates as unstable/beta because this causes network wide DNS outage and not being able to control your heating/lights.
I don’t think that your DNS problems are related to the suspected memory leak in Home Assistant OS. Unless the DNS server is running on the same system as Home Assistant and is affected by the lack of memory.
That’s why HASS OS is so important: the more core services (DHCP, DNS, Ad-Blocking, FTP, SAMBA, …) you shift to HA the worse are consequences when HA doesn’t work as intended.
So, I’ve learned over the last two years that home assistant is amazing, however…, the upgrade process is a crapshoot, be that the OS, the Supervisor, or Core…, they all suck.
The latest upgrade from core 2020.12 1 to 2020.12.2 nuked my system, booted but no Lovelace. tried a restore from snapshot via the command line, did nothing, tried to manually roll back, did nothing. CPU load average was 11 (normally 0.3), after 6 hours of grief I just wiped and rebuilt the SD card and restored a snapshot. This has become par for the course during the he last 6 months.
My advice, create snapshots and copy them somewhere safe before doing any kind of upgrade (I use this https://github.com/sabeechen/hassio-google-drive-backup ), the roll back system has never worked for me, and restoring from snapshots is very unreliable, unless done during a complete fresh install.
Pi3B+,HA OS 5.9, Supervisor 2020.12.7, Core 2020.12.1
nothing to do I followed various guides for modifying the bootloader but they are for rpi4 I use rpi3 … today I installed an image from github with hassos 4.20 and fortunately my snapshot that I had made on December 3rd was successfully loaded. … from now on i think i will no longer update hassOS on my ssd … i will play with other ssd first before putting it into production
