Supervisor fails to update to 2022.10.2 and exits afterwards.
Starting it again and it is back up on 2022.10.0. Sometimes a restart makes it exit as wall.
Strange behavior and I can’t find anything in the logs besides that it fails.
Information about the installation
Version core-2022.10.5
Installation Type Home Assistant Supervised
Development false
Supervisor true
Docker true
User root
Virtual Environment false
Python Version 3.10.5
Operating System Family Linux
Operating System Version 5.10.0-9-amd64
CPU Architecture x86_64
Home Assistant Supervisor
Host Operating System Debian GNU/Linux 11 (bullseye)
Update Channel stable
Supervisor Version supervisor-2022.10.0
Agent Version 1.4.1
Docker Version 20.10.18
Disk Total 455.5 GB
Disk Used 36.9 GB
Healthy Unhealthy
Supported true
Supervisor API ok
Version API ok
Unhealthy links to Supervisor was not able to update - Home Assistant
Tried CLI command ha supervisor update, same result.
Logs from hassio_supervisor
22-11-06 16:36:13 INFO (MainThread) [supervisor.supervisor] Update Supervisor to version 2022.10.2
22-11-06 16:36:13 INFO (SyncWorker_2) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/amd64-hassio-supervisor with tag 2022.10.2.
22-11-06 16:36:17 INFO (MainThread) [supervisor.docker.monitor] Stopped docker events monitor
22-11-06 16:36:17 INFO (MainThread) [supervisor.misc.scheduler] Shutting down scheduled tasks
22-11-06 16:36:22 INFO (MainThread) [supervisor.api] Stopping API on 172.30.32.2
22-11-06 16:36:22 INFO (MainThread) [supervisor.hardware.monitor] Stopped Supervisor hardware monitor
22-11-06 16:36:22 INFO (MainThread) [supervisor.dbus.manager] Closed conection to system D-Bus.
22-11-06 16:36:22 WARNING (MainThread) [supervisor.homeassistant.websocket] Connection is closed
22-11-06 16:36:22 INFO (MainThread) [supervisor.core] Supervisor is down - 0
22-11-06 16:36:22 INFO (MainThread) [__main__] Closing Supervisor
[15:36:22] WARNING: Halt Supervisor
[15:36:22] INFO: Supervisor restart after closing
s6-rc: info: service legacy-services: stopping
[15:36:22] INFO: Watchdog restart after closing
s6-svwait: fatal: supervisor died
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/udev.sh
[15:38:37] INFO: Using udev information from host
cont-init: info: /etc/cont-init.d/udev.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun supervisor (no readiness notification)
services-up: info: copying legacy longrun watchdog (no readiness notification)
s6-rc: info: service legacy-services successfully started
[15:38:37] INFO: Starting local supervisor watchdog...
22-11-06 15:38:38 INFO (MainThread) [__main__] Initializing Supervisor setup
22-11-06 15:38:38 INFO (MainThread) [supervisor.bootstrap] Initializing Supervisor Sentry
22-11-06 16:38:38 INFO (MainThread) [supervisor.bootstrap] Seting up coresys for machine: intel-nuc
22-11-06 16:38:38 INFO (SyncWorker_0) [supervisor.docker.supervisor] Attaching to Supervisor homeassistant/amd64-hassio-supervisor with version 2022.10.0
22-11-06 16:38:38 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
22-11-06 16:38:38 INFO (SyncWorker_1) [supervisor.docker.interface] Cleanup images: ['ghcr.io/home-assistant/amd64-hassio-supervisor:2022.10.2']
22-11-06 16:38:38 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.INITIALIZE
22-11-06 16:38:38 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-11-06 16:38:38 ERROR (MainThread) [supervisor.core] Update '2022.10.2' of Supervisor '2022.10.0' failed!
22-11-06 16:38:38 INFO (MainThread) [supervisor.resolution.module] Create new issue IssueType.UPDATE_ROLLBACK - ContextType.SUPERVISOR / None
22-11-06 16:38:38 INFO (MainThread) [__main__] Setting up Supervisor
22-11-06 16:38:38 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
22-11-06 16:38:38 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
22-11-06 16:38:38 INFO (MainThread) [supervisor.dbus.manager] Connected to system D-Bus.
22-11-06 16:38:38 INFO (MainThread) [supervisor.dbus.agent] Load dbus interface io.hass.os
22-11-06 16:38:38 INFO (MainThread) [supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
22-11-06 16:38:38 INFO (MainThread) [supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
22-11-06 16:38:38 INFO (MainThread) [supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
22-11-06 16:38:38 INFO (MainThread) [supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
22-11-06 16:38:38 INFO (MainThread) [supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
22-11-06 16:38:38 INFO (MainThread) [supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
22-11-06 16:38:38 INFO (MainThread) [supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
22-11-06 16:38:38 WARNING (MainThread) [supervisor.dbus.manager] Can't load dbus interface de.pengutronix.rauc: The name de.pengutronix.rauc was not provided by any .service files
22-11-06 16:38:38 INFO (MainThread) [supervisor.host.services] Updating service information
22-11-06 16:38:38 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
22-11-06 16:38:39 INFO (MainThread) [supervisor.host.network] Updating local network information
22-11-06 16:38:39 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
22-11-06 16:38:39 INFO (MainThread) [supervisor.docker.monitor] Started docker events monitor
22-11-06 16:38:39 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-cli with version 2022.08.0
22-11-06 16:38:39 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-dns with version 2022.04.1
22-11-06 16:38:39 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
22-11-06 16:38:39 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-audio with version 2022.07.0
22-11-06 16:38:39 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-observer with version 2021.10.0
22-11-06 16:38:39 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-multicast with version 2022.02.0
22-11-06 16:38:39 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
22-11-06 16:38:39 INFO (MainThread) [supervisor.plugins.manager] cli does not have the latest version 2022.11.0, updating
22-11-06 16:38:39 WARNING (MainThread) [supervisor.jobs] 'PluginCli.update' blocked from execution, system is not healthy
22-11-06 16:38:39 ERROR (MainThread) [supervisor.plugins.manager] Can't update cli to 2022.11.0, the Supervisor healthy could be compromised!
22-11-06 16:38:39 INFO (MainThread) [supervisor.resolution.module] Create new suggestion SuggestionType.EXECUTE_UPDATE - ContextType.PLUGIN / cli
22-11-06 16:38:39 INFO (MainThread) [supervisor.resolution.module] Create new issue IssueType.UPDATE_FAILED - ContextType.PLUGIN / cli
22-11-06 16:38:39 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 16 Home Assistant secrets
22-11-06 16:38:39 INFO (SyncWorker_4) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/intel-nuc-homeassistant with version 2022.10.5
22-11-06 16:38:39 INFO (MainThread) [supervisor.os.manager] No Home Assistant Operating System found
22-11-06 16:38:39 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/cebe7a76 repository
22-11-06 16:38:39 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/core repository
22-11-06 16:38:39 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/a0d7b954 repository
22-11-06 16:38:39 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/5c53de3b repository
22-11-06 16:38:39 INFO (MainThread) [supervisor.store] Loading add-ons from store: 69 all - 69 new - 0 remove
22-11-06 16:38:39 INFO (MainThread) [supervisor.addons] Found 12 installed add-ons
22-11-06 16:38:39 INFO (SyncWorker_2) [supervisor.docker.interface] Attaching to ghcr.io/hassio-addons/ssh/amd64 with version 12.0.2
22-11-06 16:38:39 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/hassio-addons/log-viewer/amd64 with version 0.14.0
22-11-06 16:38:39 INFO (SyncWorker_4) [supervisor.docker.interface] Attaching to sabeechen/hassio-google-drive-backup-amd64 with version 0.108.4
22-11-06 16:38:39 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/hassio-addons/influxdb/amd64 with version 4.5.0
22-11-06 16:38:39 INFO (SyncWorker_3) [supervisor.docker.interface] Attaching to ghcr.io/hassio-addons/nut/amd64 with version 0.11.0
22-11-06 16:38:39 INFO (SyncWorker_6) [supervisor.docker.interface] Attaching to ghcr.io/hassio-addons/grafana/amd64 with version 8.0.2
22-11-06 16:38:39 INFO (SyncWorker_5) [supervisor.docker.interface] Attaching to homeassistant/amd64-addon-configurator with version 5.4.1
22-11-06 16:38:39 INFO (SyncWorker_7) [supervisor.docker.interface] Attaching to homeassistant/amd64-addon-deconz with version 6.17.0
22-11-06 16:38:39 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/hassio-addons/vscode/amd64 with version 5.4.0
22-11-06 16:38:39 INFO (SyncWorker_4) [supervisor.docker.interface] Attaching to ghcr.io/hassio-addons/glances/amd64 with version 0.16.0
22-11-06 16:38:39 INFO (SyncWorker_3) [supervisor.docker.interface] Attaching to homeassistant/amd64-addon-zwave_js with version 0.1.74
22-11-06 16:38:39 INFO (SyncWorker_2) [supervisor.docker.interface] Attaching to homeassistant/amd64-addon-check_config with version 3.11.0
22-11-06 16:38:39 INFO (MainThread) [supervisor.backups.manager] Found 16 backup files
22-11-06 16:38:40 INFO (MainThread) [supervisor.discovery] Loaded 2 messages
22-11-06 16:38:40 INFO (MainThread) [supervisor.ingress] Loaded 31 ingress sessions
22-11-06 16:38:40 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.SETUP
22-11-06 16:38:40 INFO (MainThread) [supervisor.resolution.check] System checks complete
22-11-06 16:38:40 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.SETUP
22-11-06 16:38:40 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-11-06 16:38:40 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not healthy
22-11-06 16:38:40 INFO (MainThread) [__main__] Running Supervisor
22-11-06 16:38:40 CRITICAL (MainThread) [supervisor.core] System is running in an unhealthy state and needs manual intervention!
22-11-06 16:38:40 INFO (MainThread) [supervisor.jobs] 'OSManager.mark_healthy' blocked from execution, no Home Assistant OS available
22-11-06 16:38:40 WARNING (MainThread) [supervisor.core] Ignoring Supervisor updates!
22-11-06 16:38:40 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.INITIALIZE' starting 0 add-ons
22-11-06 16:38:40 INFO (MainThread) [supervisor.core] Supervisor reboot detected
22-11-06 16:38:40 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
22-11-06 16:38:40 INFO (MainThread) [supervisor.core] Supervisor is up and running
22-11-06 16:38:40 INFO (MainThread) [supervisor.host.info] Updating local host information
22-11-06 16:38:40 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.RUNNING
22-11-06 16:38:40 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.FREE_SPACE/ContextType.SYSTEM
22-11-06 16:38:40 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.SECURITY/ContextType.CORE
22-11-06 16:38:40 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.SUPERVISOR
22-11-06 16:38:40 INFO (MainThread) [supervisor.host.services] Updating service information
22-11-06 16:38:40 INFO (MainThread) [supervisor.host.network] Updating local network information
22-11-06 16:38:40 INFO (MainThread) [supervisor.host.manager] Host information reload completed
22-11-06 16:38:40 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.NO_CURRENT_BACKUP/ContextType.SYSTEM
22-11-06 16:38:40 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.PWNED/ContextType.ADDON
22-11-06 16:38:40 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.IPV4_CONNECTION_PROBLEM/ContextType.SYSTEM
22-11-06 16:38:40 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_FAILED/ContextType.DNS_SERVER
22-11-06 16:38:40 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_IPV6_ERROR/ContextType.DNS_SERVER
22-11-06 16:38:40 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
22-11-06 16:42:10 INFO (MainThread) [supervisor.api.middleware.security] /supervisor/info access from a0d7b954_ssh
22-11-06 16:42:26 INFO (MainThread) [supervisor.supervisor] Fetching AppArmor profile https://version.home-assistant.io/apparmor.txt
22-11-06 16:42:26 INFO (MainThread) [supervisor.host.apparmor] Adding/updating AppArmor profile: hassio-supervisor
22-11-06 16:42:26 INFO (MainThread) [supervisor.supervisor] Update Supervisor to version 2022.10.2
22-11-06 16:42:26 INFO (SyncWorker_6) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/amd64-hassio-supervisor with tag 2022.10.2.
22-11-06 16:42:30 INFO (MainThread) [supervisor.docker.monitor] Stopped docker events monitor
22-11-06 16:42:30 INFO (MainThread) [supervisor.misc.scheduler] Shutting down scheduled tasks
22-11-06 16:42:30 INFO (MainThread) [supervisor.api] Stopping API on 172.30.32.2
22-11-06 16:42:30 INFO (MainThread) [supervisor.dbus.manager] Closed conection to system D-Bus.
22-11-06 16:42:30 INFO (MainThread) [supervisor.hardware.monitor] Stopped Supervisor hardware monitor
22-11-06 16:42:30 WARNING (MainThread) [supervisor.homeassistant.websocket] Connection is closed
22-11-06 16:42:30 INFO (MainThread) [supervisor.core] Supervisor is down - 0
22-11-06 16:42:30 INFO (MainThread) [__main__] Closing Supervisor
[15:42:30] WARNING: Halt Supervisor
[15:42:30] INFO: Supervisor restart after closing
[15:42:30] INFO: Watchdog restart after closing
[15:44:52] INFO: Using udev information from host
[15:44:52] INFO: Starting local supervisor watchdog...
22-11-06 15:44:52 INFO (MainThread) [__main__] Initializing Supervisor setup
22-11-06 15:44:52 INFO (MainThread) [supervisor.bootstrap] Initializing Supervisor Sentry
22-11-06 16:44:52 INFO (MainThread) [supervisor.bootstrap] Seting up coresys for machine: intel-nuc
22-11-06 16:44:52 INFO (SyncWorker_0) [supervisor.docker.supervisor] Attaching to Supervisor homeassistant/amd64-hassio-supervisor with version 2022.10.0
22-11-06 16:44:52 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
22-11-06 16:44:52 INFO (SyncWorker_1) [supervisor.docker.interface] Cleanup images: ['ghcr.io/home-assistant/amd64-hassio-supervisor:2022.10.2']
22-11-06 16:44:52 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.INITIALIZE
22-11-06 16:44:52 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-11-06 16:44:52 ERROR (MainThread) [supervisor.core] Update '2022.10.2' of Supervisor '2022.10.0' failed!
22-11-06 16:44:52 INFO (MainThread) [supervisor.resolution.module] Create new issue IssueType.UPDATE_ROLLBACK - ContextType.SUPERVISOR / None
22-11-06 16:44:52 INFO (MainThread) [__main__] Setting up Supervisor
22-11-06 16:44:52 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
22-11-06 16:44:52 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
22-11-06 16:44:52 INFO (MainThread) [supervisor.dbus.manager] Connected to system D-Bus.
22-11-06 16:44:52 INFO (MainThread) [supervisor.dbus.agent] Load dbus interface io.hass.os
22-11-06 16:44:52 INFO (MainThread) [supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
22-11-06 16:44:52 INFO (MainThread) [supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
22-11-06 16:44:52 INFO (MainThread) [supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
22-11-06 16:44:52 INFO (MainThread) [supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
22-11-06 16:44:52 INFO (MainThread) [supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
22-11-06 16:44:52 INFO (MainThread) [supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
22-11-06 16:44:52 INFO (MainThread) [supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
22-11-06 16:44:53 WARNING (MainThread) [supervisor.dbus.manager] Can't load dbus interface de.pengutronix.rauc: The name de.pengutronix.rauc was not provided by any .service files
22-11-06 16:44:53 INFO (MainThread) [supervisor.host.services] Updating service information
22-11-06 16:44:53 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
22-11-06 16:44:53 INFO (MainThread) [supervisor.host.network] Updating local network information
22-11-06 16:44:53 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
22-11-06 16:44:53 INFO (MainThread) [supervisor.docker.monitor] Started docker events monitor
22-11-06 16:44:53 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-cli with version 2022.08.0
22-11-06 16:44:53 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-dns with version 2022.04.1
22-11-06 16:44:53 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
22-11-06 16:44:53 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-audio with version 2022.07.0
22-11-06 16:44:53 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-observer with version 2021.10.0
22-11-06 16:44:53 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-multicast with version 2022.02.0
22-11-06 16:44:53 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
22-11-06 16:44:53 INFO (MainThread) [supervisor.plugins.manager] cli does not have the latest version 2022.11.0, updating
22-11-06 16:44:53 WARNING (MainThread) [supervisor.jobs] 'PluginCli.update' blocked from execution, system is not healthy
22-11-06 16:44:53 ERROR (MainThread) [supervisor.plugins.manager] Can't update cli to 2022.11.0, the Supervisor healthy could be compromised!
22-11-06 16:44:53 INFO (MainThread) [supervisor.resolution.module] Create new suggestion SuggestionType.EXECUTE_UPDATE - ContextType.PLUGIN / cli
22-11-06 16:44:53 INFO (MainThread) [supervisor.resolution.module] Create new issue IssueType.UPDATE_FAILED - ContextType.PLUGIN / cli
22-11-06 16:44:53 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/intel-nuc-homeassistant with version 2022.10.5
22-11-06 16:44:53 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 16 Home Assistant secrets
22-11-06 16:44:53 INFO (MainThread) [supervisor.os.manager] No Home Assistant Operating System found
22-11-06 16:44:53 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/cebe7a76 repository
22-11-06 16:44:53 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/5c53de3b repository
22-11-06 16:44:53 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/core repository
22-11-06 16:44:53 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/a0d7b954 repository
22-11-06 16:44:53 INFO (MainThread) [supervisor.store] Loading add-ons from store: 69 all - 69 new - 0 remove
22-11-06 16:44:53 INFO (MainThread) [supervisor.addons] Found 12 installed add-ons
22-11-06 16:44:53 INFO (SyncWorker_5) [supervisor.docker.interface] Attaching to homeassistant/amd64-addon-configurator with version 5.4.1
22-11-06 16:44:53 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/hassio-addons/vscode/amd64 with version 5.4.0
22-11-06 16:44:53 INFO (SyncWorker_4) [supervisor.docker.interface] Attaching to sabeechen/hassio-google-drive-backup-amd64 with version 0.108.4
22-11-06 16:44:53 INFO (SyncWorker_3) [supervisor.docker.interface] Attaching to ghcr.io/hassio-addons/log-viewer/amd64 with version 0.14.0
22-11-06 16:44:53 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/hassio-addons/glances/amd64 with version 0.16.0
22-11-06 16:44:53 INFO (SyncWorker_7) [supervisor.docker.interface] Attaching to ghcr.io/hassio-addons/nut/amd64 with version 0.11.0
22-11-06 16:44:53 INFO (SyncWorker_6) [supervisor.docker.interface] Attaching to ghcr.io/hassio-addons/grafana/amd64 with version 8.0.2
22-11-06 16:44:53 INFO (SyncWorker_5) [supervisor.docker.interface] Attaching to ghcr.io/hassio-addons/influxdb/amd64 with version 4.5.0
22-11-06 16:44:53 INFO (SyncWorker_2) [supervisor.docker.interface] Attaching to ghcr.io/hassio-addons/ssh/amd64 with version 12.0.2
22-11-06 16:44:53 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to homeassistant/amd64-addon-zwave_js with version 0.1.74
22-11-06 16:44:54 INFO (SyncWorker_3) [supervisor.docker.interface] Attaching to homeassistant/amd64-addon-deconz with version 6.17.0
22-11-06 16:44:54 INFO (SyncWorker_4) [supervisor.docker.interface] Attaching to homeassistant/amd64-addon-check_config with version 3.11.0
22-11-06 16:44:54 INFO (MainThread) [supervisor.backups.manager] Found 16 backup files
22-11-06 16:44:54 INFO (MainThread) [supervisor.discovery] Loaded 2 messages
22-11-06 16:44:54 INFO (MainThread) [supervisor.ingress] Loaded 31 ingress sessions
22-11-06 16:44:54 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.SETUP
22-11-06 16:44:54 INFO (MainThread) [supervisor.resolution.check] System checks complete
22-11-06 16:44:54 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.SETUP
22-11-06 16:44:54 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-11-06 16:44:54 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not healthy
22-11-06 16:44:54 INFO (MainThread) [__main__] Running Supervisor
22-11-06 16:44:54 CRITICAL (MainThread) [supervisor.core] System is running in an unhealthy state and needs manual intervention!
22-11-06 16:44:54 INFO (MainThread) [supervisor.jobs] 'OSManager.mark_healthy' blocked from execution, no Home Assistant OS available
22-11-06 16:44:54 WARNING (MainThread) [supervisor.core] Ignoring Supervisor updates!
22-11-06 16:44:54 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.INITIALIZE' starting 0 add-ons
22-11-06 16:44:54 INFO (MainThread) [supervisor.core] Supervisor reboot detected
22-11-06 16:44:54 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
22-11-06 16:44:54 INFO (MainThread) [supervisor.core] Supervisor is up and running
22-11-06 16:44:54 INFO (MainThread) [supervisor.host.info] Updating local host information
22-11-06 16:44:54 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.RUNNING
22-11-06 16:44:54 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.FREE_SPACE/ContextType.SYSTEM
22-11-06 16:44:54 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.SECURITY/ContextType.CORE
22-11-06 16:44:54 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.SUPERVISOR
22-11-06 16:44:54 INFO (MainThread) [supervisor.host.services] Updating service information
22-11-06 16:44:54 INFO (MainThread) [supervisor.host.network] Updating local network information
22-11-06 16:44:54 INFO (MainThread) [supervisor.host.manager] Host information reload completed
22-11-06 16:44:54 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.NO_CURRENT_BACKUP/ContextType.SYSTEM
22-11-06 16:44:54 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.PWNED/ContextType.ADDON
22-11-06 16:44:54 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.IPV4_CONNECTION_PROBLEM/ContextType.SYSTEM
22-11-06 16:44:54 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_FAILED/ContextType.DNS_SERVER
22-11-06 16:44:54 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_IPV6_ERROR/ContextType.DNS_SERVER
22-11-06 16:44:54 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
I’m stuck in a catch-22 situation, please advise what to do
