after the last update 2023.9.1 the modbus outgoing commands send the control panel offline and to reactivate I have to restart the configuration file or restart the home assistant, while the received signals do not give problems.
some idea ?
I tried with version 2023.7.3 and it works without losing the connection on the control panel
Hi, after release 2023.9.1 I have the same problem. I reloaded the previous version 2023.9.0 and it go.
I think there is a bug in the 2023.9.1 version.
Same problem here, seems that after release 2023.9.1 all register values become “unavailable” after 5 min. there should be a fix for that problem in the pymodbus version v3.5.2(@ janiversen (jan iversen) · GitHub ) but how do you get this update in to HA
Second attempt. I then took a closer look at the error message. There is a breaking change that has not been announced.
I had defined the property count when reading several registers of the same type (data_type: int16). But the doc now says:
Number of registers to read. only valid for data_type: custom and data_type: string , for other data types count is automatically calculated.
I then removed count from these registers and now it works.
Sorry for the wrong statement that it still doesn’t work.
