I’d assume this is possible, but I can’t find a way to do it…
Essentially I want to find a way to update a variable that can be used throughout HA.
For instance, suppose I have a variable called lightsOnOutside and I set it to true. I then add a condition to my “Turn the backyard lights off” automation that will only turn those lights off if lightsOnOutside is false. I would then use a control in a Dashboard to toggle the lightsOnOutside variable.
