Update arduio via raspberry with Hass.io
I want to update the firmware of arduino, connected to raspberry. I imagine this as follows:
  1. I write the code for arduino on the PC, and probably compile it if need.
  2. Next I go to the Raspberry via PuTTY and transmission the code (binary or source)
  3. I update firmware of the Arduino
It can do PlatformIO, but I cannot to install it, since it needs a Python. There is no Python in Hassio. How to be?
Up. There is no way to program arduino from hassio?
Home Assistant runs on python. If there was no python, home assistant wouldn’t work.
I think the problem here is that you don’t have access to install things (and you shouldn’t because it’s in a docker environment).
Create a new add-on yourself and configure what you need in it to communicate with your Arduino
