Update beta
I’m trying to upgrade to version 0.94.0b4 but immediately after updating, the system automatically returns to the previous version. my install was 0.94.0b1. how to stabilize the update? thank you
You’re going to need to watch the logfile in a console or something like that to see what is going wrong I think. I went from b1 to b4 just an hour ago and alls well here… in fact some nasty b2 and b3 bugs are now gone as well.
nothing appears in the log. what he sees is that the system updates to the latest version, then it seems to go offline and the previous version reappears. Even trying to update from CLI. I don’t know how it is possible to solve this situation because I think it will do so even with the stable HA version.
What about the supervisor log?
where can I find this log?
Hassio side panel>system
I think there is also another logfile. If you log into discord you can try and get the attention of @pvizeli - he’s usually around now in either beta or one of the dev forums
this is the log. but naturaly is the log of 0.94.0b1
19-06-02 08:30:04 WARNING (MainThread) [hassio.dbus.rauc] Can’t connect to rauc
19-06-02 08:30:04 INFO (MainThread) [hassio.host.info] Update local host information
19-06-02 08:30:04 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
19-06-02 08:30:04 INFO (MainThread) [hassio.host.services] Update service information
19-06-02 08:30:04 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
19-06-02 08:30:04 INFO (MainThread) [hassio.host.apparmor] Load AppArmor Profiles: {‘hassio-supervisor’}
19-06-02 08:30:04 INFO (MainThread) [hassio.host.apparmor] AppArmor is not enabled on host
19-06-02 08:30:04 INFO (SyncWorker_1) [hassio.docker.interface] Attach to homeassistant/raspberrypi3-homeassistant with version 0.94.0b1
19-06-02 08:30:05 ERROR (MainThread) [hassio.utils.json] Can’t read json from /data/addons/git/d421102b/repository.json: [Errno 2] No such file or directory: ‘/data/addons/git/d421102b/repository.json’
19-06-02 08:30:05 WARNING (MainThread) [hassio.store.data] Can’t read repository information from /data/addons/git/d421102b/repository.json
19-06-02 08:30:05 ERROR (MainThread) [hassio.utils.json] Can’t read json from /data/addons/git/54d18112/repository.json: [Errno 2] No such file or directory: ‘/data/addons/git/54d18112/repository.json’
19-06-02 08:30:05 WARNING (MainThread) [hassio.store.data] Can’t read repository information from /data/addons/git/54d18112/repository.json
19-06-02 08:30:05 WARNING (MainThread) [hassio.store.data] Can’t read /data/addons/git/64f57845/magic_mirror/config.json: required key not provided @ data[‘arch’]. Got None
19-06-02 08:30:06 INFO (MainThread) [hassio.store.git] Load add-on /data/addons/git/8cc98bc5 repository
19-06-02 08:30:06 INFO (MainThread) [hassio.store.git] Load add-on /data/addons/git/3833edd4 repository
19-06-02 08:30:06 INFO (MainThread) [hassio.store.git] Load add-on /data/addons/git/a0d7b954 repository
19-06-02 08:30:06 INFO (MainThread) [hassio.store.git] Load add-on /data/addons/git/03d23610 repository
19-06-02 08:30:06 INFO (MainThread) [hassio.store.git] Load add-on /data/addons/git/7ad98f9c repository
19-06-02 08:30:06 INFO (MainThread) [hassio.store.git] Load add-on /data/addons/git/7be23ff5 repository
19-06-02 08:30:06 INFO (MainThread) [hassio.store.git] Load add-on /data/addons/git/d421102b repository
19-06-02 08:30:06 INFO (MainThread) [hassio.store.git] Load add-on /data/addons/git/54d18112 repository
19-06-02 08:30:06 INFO (MainThread) [hassio.store.git] Load add-on /data/addons/git/325f13a9 repository
19-06-02 08:30:06 INFO (MainThread) [hassio.store.git] Load add-on /data/addons/git/64f57845 repository
19-06-02 08:30:06 INFO (MainThread) [hassio.store.git] Load add-on /data/addons/core repository
19-06-02 08:30:06 ERROR (MainThread) [hassio.utils.json] Can’t read json from /data/addons/git/d421102b/repository.json: [Errno 2] No such file or directory: ‘/data/addons/git/d421102b/repository.json’
19-06-02 08:30:06 WARNING (MainThread) [hassio.store.data] Can’t read repository information from /data/addons/git/d421102b/repository.json
19-06-02 08:30:06 ERROR (MainThread) [hassio.utils.json] Can’t read json from /data/addons/git/54d18112/repository.json: [Errno 2] No such file or directory: ‘/data/addons/git/54d18112/repository.json’
19-06-02 08:30:06 WARNING (MainThread) [hassio.store.data] Can’t read repository information from /data/addons/git/54d18112/repository.json
19-06-02 08:30:06 WARNING (MainThread) [hassio.store.data] Can’t read /data/addons/git/64f57845/magic_mirror/config.json: required key not provided @ data[‘arch’]. Got None
19-06-02 08:30:06 INFO (MainThread) [hassio.store] Load add-ons from store: 67 all - 67 new - 0 remove
19-06-02 08:30:06 INFO (MainThread) [hassio.addons] Found 18 installed add-ons
19-06-02 08:30:06 INFO (SyncWorker_7) [hassio.docker.interface] Attach to hassioaddons/home-panel-armv7 with version v0.4.1
19-06-02 08:30:07 INFO (SyncWorker_15) [hassio.docker.interface] Attach to hassioaddons/adb-armv7 with version v0.4.1
19-06-02 08:30:07 INFO (SyncWorker_12) [hassio.docker.interface] Attach to hassioaddons/node-red-armv7 with version v3.1.1
19-06-02 08:30:07 INFO (SyncWorker_0) [hassio.docker.interface] Attach to homeassistant/armv7-addon-check_config with version 2.0
19-06-02 08:30:07 INFO (SyncWorker_11) [hassio.docker.interface] Attach to dwelch2101/dropbox-sync-armhf with version 1.3.0
19-06-02 08:30:07 INFO (SyncWorker_1) [hassio.docker.interface] Attach to homeassistant/armv7-addon-mosquitto with version 4.2
19-06-02 08:30:07 INFO (SyncWorker_8) [hassio.docker.interface] Attach to homeassistant/armv7-addon-ssh with version 5.4
19-06-02 08:30:07 INFO (SyncWorker_2) [hassio.docker.interface] Attach to hassioaddons/spotify-armv7 with version v0.5.2
19-06-02 08:30:07 INFO (SyncWorker_9) [hassio.docker.interface] Attach to homeassistant/armv7-addon-samba with version 8.1
19-06-02 08:30:07 INFO (SyncWorker_3) [hassio.docker.interface] Attach to homeassistant/armv7-addon-configurator with version 3.4
19-06-02 08:30:07 INFO (SyncWorker_10) [hassio.docker.interface] Attach to hassioaddons/appdaemon3-armv7 with version v3.0.2
19-06-02 08:30:07 INFO (SyncWorker_14) [hassio.docker.interface] Attach to samccauley/armhf-googlebackup with version 1.6.1
19-06-02 08:30:07 INFO (SyncWorker_7) [hassio.docker.interface] Attach to hassioaddons/log-viewer-armv7 with version v0.5.1
19-06-02 08:30:07 INFO (SyncWorker_5) [hassio.docker.interface] Attach to dwelch2101/zigbee2mqtt-armhf with version 1.4.0
19-06-02 08:30:07 INFO (SyncWorker_17) [hassio.docker.interface] Attach to homeassistant/armv7-addon-duckdns with version 1.6
19-06-02 08:30:07 INFO (SyncWorker_4) [hassio.docker.interface] Attach to homeassistant/armv7-addon-rpc_shutdown with version 1.0
19-06-02 08:30:07 INFO (SyncWorker_15) [hassio.docker.interface] Attach to homeassistant/armv7-addon-cec_scan with version 2.1
19-06-02 08:30:07 INFO (SyncWorker_16) [hassio.docker.interface] Attach to hassioaddons/aircast-armv7 with version v2.0.2
19-06-02 08:30:07 INFO (MainThread) [hassio.updater] Fetch update data from https://s3.amazonaws.com/hassio-version/beta.json
19-06-02 08:30:08 INFO (MainThread) [hassio.snapshots] Found 25 snapshot files
19-06-02 08:30:09 INFO (MainThread) [hassio.discovery] Load 1 messages
19-06-02 08:30:09 INFO (MainThread) [hassio.ingress] Load 0 ingress session
19-06-02 08:30:09 INFO (MainThread) [main] Run Hass.io
19-06-02 08:30:09 INFO (MainThread) [hassio.misc.dns] Start DNS port forwarding for host add-ons
19-06-02 08:30:09 INFO (MainThread) [hassio.api] Start API on 172.30.32.2
19-06-02 08:30:09 INFO (MainThread) [hassio.addons] Phase ‘initialize’ start 0 add-ons
19-06-02 08:30:09 INFO (MainThread) [hassio.addons] Phase ‘system’ start 1 add-ons
19-06-02 08:30:14 INFO (SyncWorker_9) [hassio.docker.addon] Start Docker add-on homeassistant/armv7-addon-mosquitto with version 4.2
19-06-02 08:30:17 INFO (MainThread) [hassio.services.modules.mqtt] Set core_mosquitto as service provider for mqtt
19-06-02 08:30:17 INFO (MainThread) [hassio.discovery] Duplicate discovery message from core_mosquitto
19-06-02 08:30:19 INFO (MainThread) [hassio.addons] Phase ‘services’ start 9 add-ons
19-06-02 08:30:20 INFO (MainThread) [hassio.host.alsa] Update ALSA device list
19-06-02 08:30:23 INFO (SyncWorker_1) [hassio.docker.addon] Start Docker add-on homeassistant/armv7-addon-rpc_shutdown with version 1.0
19-06-02 08:30:27 INFO (SyncWorker_9) [hassio.docker.addon] Start Docker add-on hassioaddons/aircast-armv7 with version v2.0.2
19-06-02 08:30:28 INFO (SyncWorker_16) [hassio.docker.addon] Start Docker add-on homeassistant/armv7-addon-samba with version 8.1
19-06-02 08:30:31 INFO (SyncWorker_0) [hassio.docker.addon] Start Docker add-on hassioaddons/spotify-armv7 with version v0.5.2
19-06-02 08:30:33 INFO (MainThread) [hassio.api.security] /host/info access from a0d7b954_aircast
19-06-02 08:30:33 INFO (SyncWorker_8) [hassio.docker.addon] Start Docker add-on samccauley/armhf-googlebackup with version 1.6.1
19-06-02 08:30:34 INFO (SyncWorker_2) [hassio.docker.addon] Start Docker add-on homeassistant/armv7-addon-duckdns with version 1.6
19-06-02 08:30:35 INFO (SyncWorker_4) [hassio.docker.addon] Start Docker add-on homeassistant/armv7-addon-ssh with version 5.4
19-06-02 08:30:35 INFO (SyncWorker_19) [hassio.docker.addon] Start Docker add-on dwelch2101/zigbee2mqtt-armhf with version 1.4.0
19-06-02 08:30:36 INFO (SyncWorker_11) [hassio.docker.addon] Start Docker add-on hassioaddons/adb-armv7 with version v0.4.1
19-06-02 08:30:36 INFO (MainThread) [hassio.api.security] /host/info access from a0d7b954_spotify
19-06-02 08:30:40 INFO (MainThread) [hassio.api.security] /host/info access from a0d7b954_adb
19-06-02 08:30:41 INFO (SyncWorker_12) [hassio.docker.interface] Start homeassistant/raspberrypi3-homeassistant
19-06-02 08:36:04 INFO (MainThread) [hassio.homeassistant] Detect a running Home Assistant instance
19-06-02 08:36:04 INFO (MainThread) [hassio.addons] Phase ‘application’ start 5 add-ons
19-06-02 08:36:05 WARNING (MainThread) [hassio.addons.validate] Unknown options port
19-06-02 08:36:05 WARNING (MainThread) [hassio.addons.validate] Unknown options username
19-06-02 08:36:05 WARNING (MainThread) [hassio.addons.validate] Unknown options password
19-06-02 08:36:05 WARNING (MainThread) [hassio.addons.validate] Unknown options filters
19-06-02 08:36:17 INFO (SyncWorker_6) [hassio.docker.addon] Start Docker add-on hassioaddons/node-red-armv7 with version v3.1.1
19-06-02 08:36:27 INFO (SyncWorker_0) [hassio.docker.addon] Start Docker add-on homeassistant/armv7-addon-configurator with version 3.4
19-06-02 08:36:28 INFO (SyncWorker_12) [hassio.docker.addon] Start Docker add-on hassioaddons/home-panel-armv7 with version v0.4.1
19-06-02 08:36:29 INFO (SyncWorker_8) [hassio.docker.addon] Start Docker add-on hassioaddons/appdaemon3-armv7 with version v3.0.2
19-06-02 08:36:30 INFO (SyncWorker_18) [hassio.docker.addon] Start Docker add-on hassioaddons/log-viewer-armv7 with version v0.5.1
19-06-02 08:36:34 INFO (MainThread) [hassio.api.security] /host/info access from a0d7b954_nodered
19-06-02 08:36:35 INFO (MainThread) [hassio.tasks] All core tasks are scheduled
19-06-02 08:36:35 INFO (MainThread) [hassio.core] Hass.io is up and running
19-06-02 08:36:40 INFO (MainThread) [hassio.api.security] /host/info access from a0d7b954_home-panel
19-06-02 08:36:41 INFO (MainThread) [hassio.api.security] /host/info access from a0d7b954_appdaemon3
19-06-02 08:36:42 INFO (MainThread) [hassio.api.security] /host/info access from a0d7b954_logviewer
19-06-02 08:39:04 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-06-02 08:39:05 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
19-06-02 08:39:19 INFO (MainThread) [hassio.homeassistant] Updated Home Assistant API token
19-06-02 08:39:21 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request running
19-06-02 08:40:01 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-06-02 08:40:01 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_nodered
19-06-02 08:40:23 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request running
is there a system to do a forced update? the system automatically returns to the previous version? @pvizeli
