Hi. I’m using the updates card with the conditional card. If an HA update is available, the update card appears nicely, but for some unknown reason, at the same time it shows that the HA version actually does not need an update. (old version nr and new version nr are the same) You can’t start the update from the card either. When I go to the updates page in the settings, the initiating update works without problems. Maybe someone has an idea what the problem is.
The update is probably on the way to the update site, but the sensor is just updated before that has file is there.
I have experienced the same at one time and found that the update sensor was looking at the wrong place.
Here are the different places listed: Version - Home Assistant
