Update DateTime Helper a bit anoying, suggestions?
I’m using a datetime helper to be able to adjust the time I start my irrigation. It works fine as a variable, but changing the time on the lovelace dashboard is a bit anoying. I’m only able to change one digit at once. A bit hard to explain in words, but the gif/video shows the issue. I’m not able to type “22” at once, first I can type a “2”, then I can say “22”. I think the issue is that it updates on change?
Any suggestions how to solve this or how to setup a different helper / variable time?
TImeHelperIssue
