Update doesn't Install
Newbie here so apologies if this is a basic question.
Installed HA on a RPi4 over a couple of days ago and just basically playing with it sense.
Got 2 notifications to update and these seem to go ok.
Now got a notice to update OS from 8.5 to 9.0 but get the following error
[548200718512] Error updating Home Assistant Operating System: 'OSManager.update' blocked from execution, no supervisor internet connection
Any ideas how to resolve? Cant seem to find anything similar in the forums
okā€¦I rebooted the Pi and that seemed to fix the issueā€¦but not sure why?
Any ideas?
Same here on a Pi 3B, coming from HAOS 8.5:
[547931193200] Error updating Home Assistant Operating System: ā€˜OSManager.updateā€™ blocked from execution, system is not running - CoreState.STARTUP
Several hardware reboots didnā€™t fix it, unfortunately.
That is not the same error.
You are correct. :grinning: I received the other error as well, earlier.
No other services are having problems with network access, which is why I provided the second message in case another user has seen it as well.
Just casting a wide net to see whether someone with more experience than I have recognizes the situation.
Aaaaaand after about a dozen attempts, suddenly today it simply works.
Previous attempts would have a progress indicator for six or eight minutes, which would disappear, then the system would reboot, and then come up still on HAOS 8.5.
I wish I knew what I could do differently next time, other than ā€œwait until Day Two,ā€ I guess. :grinning:
