I found this great solution by tom_I:
I set the scan_interval to 157680000 (5 years)
And added this automation:
- id: "1735209965759"
alias: Update all Neevo readings
description: ""
triggers:
- trigger: time
at: 00:10:00
conditions: []
actions:
- action: homeassistant.update_entity
metadata: {}
entity_id:
- sensor.propane_tank_neevo_371_gallons
- sensor.propane_tank_neevo_125_gallons
- sensor.propane_tank_neevo_629_gallons
- sensor.propane_tank_neevo_76_gallons
- sensor.propane_tank_neevo_255_gallons
- sensor.propane_tank_neevo_630_gallons
- sensor.propane_tank_neevo_6_gallons
- sensor.tank_utility_003200223638383015473830
mode: single
Is there a way in HA to check if the CL sensor was successfully updated by running this automation?
