Update Entity - How can I adress the `up-tp-date`-info?
I found a lot the last days in here, but can you tell me how I can adress this information manually
like mushroom-update-card does automatically.
blog_question_update
states(…) shows only off and it seems to be no attribute because its not in the attributes-list.
hi,
i did it like this
  • go to the dashboard
  • add a card
  • select 'by entities
  • search for 'home assistant
  • select the entries you want
i have created the following card:
  cards:
    - type: entities
      entities:
        - entity: update.check_home_assistant_configuration_update
          secondary_info: last-changed
        - entity: update.home_assistant_core_update
        - entity: update.home_assistant_operating_system_update
        - entity: update.home_assistant_supervisor_update
        - entity: sensor.home_assistant_operating_system_newest_version
        - entity: sensor.home_assistant_operating_system_version
      state_color: true
      title: Home Assistant
If you do not see sensors, they may be disabled.
I have done the following steps to activate them
  • Settings
  • Entities
  • search for ‘home assistant’
    If you see the ‘deactivated’ icon in the right column, click on it and activate the entity in the next window.
thx man. i have to give more details. my fault. i built the following card. my goal is, if there is a new version. that the 3 text-values change from green to red to make it more eye-catching… but the if-then statements are not functioning.
i found al lot of examples using “is_state” and not statements where two sensors were compared. and ive got the idea to make something like is_state(…)=‘up-top-date’ or so. but i could not get it to work.
screenshot_update_problem
type: entities
show_header_toggle: false
entities:
  - type: custom:multiple-entity-row
    icon_type: entity-picture
    show_state: false
    entities:
        attribute: installed_version
        tap_action:
          action: none
        attribute: latest_version
        tap_action:
          action: none
    style:
      hui-generic-entity-row:
          .info.pointer {
            {% if
            state_attr('update.home_assistant_core_update','installed_version') | string
            state_attr('update.home_assistant_core_update','latest_version') | string
              color: green;
            {% else %}
              color: red;
            {% endif %}
          div.entity:nth-child(2) span {
            {% if
              color: green;
            {% else %}
              color: red;
            {% endif %}
          div.entity:nth-child(2) {
            {% if
              color: green;
            {% else %}
              color: red;
            {% endif %}
  - type: custom:mushroom-update-card
    show_buttons_control: true
    icon_type: none
    layout: vertical
    secondary_info: none
    primary_info: none
    style: |
      ha-card {
          border: solid 0px ;
hi,
I have tested (the upper part) of your card and the same problems.
{{ is_state('update.home_assistant_core_update','on') }}
should do the work …
However, your IF command should work exactly the same way.
When I test it with the developer tools / template, there are no syntax errors.
BUT:
If I set a fixed color value at entity level , it works for me …
        tap_action:
            action: none
        styles:
           color: green;
another test with
        styles:
           color: {{ 'green;'}}
does not work for me.
Maybe ‘templates’ are not supported here.
In github I found several tickets to support templates.
Maybe your problem is identical to this one:
hi,
… that has left me no peace … :grinning:
it seems to work with the lovelace card_mod extension
my current test:
        tap_action:
          action: none
    card_mod:
      style: |
            .info.pointer {  .....
    icon_type: none
    layout: vertical
    primary_info: none
    card_mod:
      style: |
        ha-card {
            border: solid 0px;
OMG. Thx 4 hlp. The solution was so near. Everytime i was looking on the entities they were ‘off’, that I never saw it. My working solution is:
            style:
                  .info.pointer {
                    {% if is_state('update.home_assistant_core_update','on') %}
                      color: red;
                    {% else %}
                      color: green;
                    {% endif %}
                      color: red;
                    {% else %}
                      color: green;
                    {% endif %}
                      color: red;
                    {% else %}
                      color: green;
                    {% endif %}
