I am using the addon “Check Home Assistant configuration” to check if I should update to the latest version.
I get an installation ERROR for pillow 9.0.1.
What is this?
How to solve this?
Should I try and update nonetheless?
I am on:
Version: core-2022.2.3
Host Operating System: Home Assistant OS 7.4
Supervisor Version: supervisor-2022.01.1
Docker Version: 20.10.9
Error Log:
INFO:homeassistant.util.package:Attempting install of colorlog==6.6.0
e[1mTesting configuration at /tmp/confige[0m
INFO:homeassistant.util.package:Attempting install of aiohttp_cors==0.7.0
INFO:homeassistant.util.package:Attempting install of sqlalchemy==1.4.27
INFO:homeassistant.util.package:Attempting install of pyhaversion==21.11.1
INFO:homeassistant.util.package:Attempting install of aiodns==3.0.0
INFO:homeassistant.util.package:Attempting install of paho-mqtt==1.6.1
INFO:homeassistant.util.package:Attempting install of jsonpath==0.82
INFO:homeassistant.util.package:Attempting install of xmltodict==0.12.0
INFO:homeassistant.util.package:Attempting install of psutil==5.8.0
INFO:homeassistant.util.package:Attempting install of python-mpd2==3.0.4
INFO:homeassistant.util.package:Attempting install of home-assistant-frontend==20220203.0
INFO:homeassistant.util.package:Attempting install of pillow==9.0.1
ERROR:homeassistant.util.package:Unable to install package pillow==9.0.1: WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7547dac0>: Failed to establish a new connection: [Errno -3] Try again')': /simple/pillow/
WARNING: Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7547d250>: Failed to establish a new connection: [Errno -3] Try again')': /simple/pillow/
WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x74e22a48>: Failed to establish a new connection: [Errno -3] Try again')': /alpine-3.14/armv7/
WARNING: Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x74e22b08>: Failed to establish a new connection: [Errno -3] Try again')': /alpine-3.14/armv7/
WARNING: Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x74e22bc8>: Failed to establish a new connection: [Errno -3] Try again')': /alpine-3.14/armv7/
WARNING: Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x74e22c88>: Failed to establish a new connection: [Errno -3] Try again')': /alpine-3.14/armv7/
WARNING: Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x74e22d48>: Failed to establish a new connection: [Errno -3] Try again')': /alpine-3.14/armv7/
ERROR: Command errored out with exit status 1:
command: /usr/local/bin/python -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-njm_cng_/pillow/setup.py'"'"'; __file__='"'"'/tmp/pip-install-njm_cng_/pillow/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' bdist_wheel -d /tmp/pip-wheel-2c7d14cn
cwd: /tmp/pip-install-njm_cng_/pillow/
Complete output (80 lines):
running bdist_wheel
running build
running build_py
running egg_info
writing src/Pillow.egg-info/PKG-INFO
writing dependency_links to src/Pillow.egg-info/dependency_links.txt
writing top-level names to src/Pillow.egg-info/top_level.txt
reading manifest file 'src/Pillow.egg-info/SOURCES.txt'
reading manifest template 'MANIFEST.in'
warning: no files found matching '*.c'
warning: no files found matching '*.h'
warning: no files found matching '*.sh'
warning: no previously-included files found matching '.appveyor.yml'
warning: no previously-included files found matching '.clang-format'
warning: no previously-included files found matching '.coveragerc'
warning: no previously-included files found matching '.editorconfig'
warning: no previously-included files found matching '.readthedocs.yml'
warning: no previously-included files found matching 'codecov.yml'
warning: no previously-included files matching '.git*' found anywhere in distribution
warning: no previously-included files matching '*.pyc' found anywhere in distribution
warning: no previously-included files matching '*.so' found anywhere in distribution
no previously-included directories found matching '.ci'
adding license file 'LICENSE'
running build_ext
The headers or library files could not be found for zlib,
a required dependency when compiling Pillow from source.
Please see the install instructions at:
https://pillow.readthedocs.io/en/latest/installation.html
File "/tmp/pip-install-njm_cng_/pillow/setup.py", line 989, in <module>
setup(
File "/usr/local/lib/python3.9/site-packages/setuptools/__init__.py", line 155, in setup
return distutils.core.setup(**attrs)
File "/usr/local/lib/python3.9/site-packages/setuptools/_distutils/core.py", line 148, in setup
return run_commands(dist)
File "/usr/local/lib/python3.9/site-packages/setuptools/_distutils/core.py", line 163, in run_commands
dist.run_commands()
File "/usr/local/lib/python3.9/site-packages/setuptools/_distutils/dist.py", line 967, in run_commands
self.run_command(cmd)
File "/usr/local/lib/python3.9/site-packages/setuptools/_distutils/dist.py", line 986, in run_command
cmd_obj.run()
File "/usr/local/lib/python3.9/site-packages/wheel/bdist_wheel.py", line 299, in run
self.run_command('build')
File "/usr/local/lib/python3.9/site-packages/setuptools/_distutils/cmd.py", line 313, in run_command
self.distribution.run_command(command)
cmd_obj.run()
File "/usr/local/lib/python3.9/site-packages/setuptools/_distutils/command/build.py", line 135, in run
self.run_command(cmd_name)
cmd_obj.run()
File "/usr/local/lib/python3.9/site-packages/setuptools/command/build_ext.py", line 79, in run
_build_ext.run(self)
File "/usr/local/lib/python3.9/site-packages/setuptools/_distutils/command/build_ext.py", line 339, in run
self.build_extensions()
File "/tmp/pip-install-njm_cng_/pillow/setup.py", line 804, in build_extensions
raise RequiredDependencyException(f)
__main__.RequiredDependencyException: zlib
File "<string>", line 1, in <module>
File "/tmp/pip-install-njm_cng_/pillow/setup.py", line 1009, in <module>
raise RequiredDependencyException(msg)
ERROR: Failed building wheel for pillow
command: /usr/local/bin/python -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-njm_cng_/pillow/setup.py'"'"'; __file__='"'"'/tmp/pip-install-njm_cng_/pillow/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-un60_l39/install-record.txt --single-version-externally-managed --compile --install-headers /usr/local/include/python3.9/pillow
Complete output (84 lines):
running install
/usr/local/lib/python3.9/site-packages/setuptools/command/install.py:34: SetuptoolsDeprecationWarning: setup.py install is deprecated. Use build and pip and other standards-based tools.
warnings.warn(
running build
running build_py
running egg_info
running build_ext
setup(
dist.run_commands()
cmd_obj.run()
File "/usr/local/lib/python3.9/site-packages/setuptools/command/install.py", line 68, in run
return orig.install.run(self)
File "/usr/local/lib/python3.9/site-packages/setuptools/_distutils/command/install.py", line 670, in run
cmd_obj.run()
cmd_obj.run()
ERROR: Command errored out with exit status 1: /usr/local/bin/python -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-njm_cng_/pillow/setup.py'"'"'; __file__='"'"'/tmp/pip-install-njm_cng_/pillow/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-un60_l39/install-record.txt --single-version-externally-managed --compile --install-headers /usr/local/include/python3.9/pillow Check the logs for full command output.
ERROR:homeassistant.util.package:Unable to install package pillow==9.0.1: WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x754b72c8>: Failed to establish a new connection: [Errno -3] Try again')': /simple/pillow/
WARNING: Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x754b7ef8>: Failed to establish a new connection: [Errno -3] Try again')': /simple/pillow/
WARNING: Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x754b7fa0>: Failed to establish a new connection: [Errno -3] Try again')': /simple/pillow/
WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x74e5ca48>: Failed to establish a new connection: [Errno -3] Try again')': /alpine-3.14/armv7/
WARNING: Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x74e5cb08>: Failed to establish a new connection: [Errno -3] Try again')': /alpine-3.14/armv7/
WARNING: Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x74e5cbc8>: Failed to establish a new connection: [Errno -3] Try again')': /alpine-3.14/armv7/
WARNING: Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x74e5cc88>: Failed to establish a new connection: [Errno -3] Try again')': /alpine-3.14/armv7/
WARNING: Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x74e5cd48>: Failed to establish a new connection: [Errno -3] Try again')': /alpine-3.14/armv7/
WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x74e5cc40>: Failed to establish a new connection: [Errno -3] Try again')': /packages/03/a3/f61a9a7ff7969cdef2a6e0383a346eb327495d20d25a2de5a088dbb543a6/Pillow-9.0.1.tar.gz
WARNING: Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x74e5ca48>: Failed to establish a new connection: [Errno -3] Try again')': /packages/03/a3/f61a9a7ff7969cdef2a6e0383a346eb327495d20d25a2de5a088dbb543a6/Pillow-9.0.1.tar.gz
WARNING: Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x74e5c880>: Failed to establish a new connection: [Errno -3] Try again')': /packages/03/a3/f61a9a7ff7969cdef2a6e0383a346eb327495d20d25a2de5a088dbb543a6/Pillow-9.0.1.tar.gz
WARNING: Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x74e5cf40>: Failed to establish a new connection: [Errno -3] Try again')': /packages/03/a3/f61a9a7ff7969cdef2a6e0383a346eb327495d20d25a2de5a088dbb543a6/Pillow-9.0.1.tar.gz
WARNING: Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x74e5cfe8>: Failed to establish a new connection: [Errno -3] Try again')': /packages/03/a3/f61a9a7ff7969cdef2a6e0383a346eb327495d20d25a2de5a088dbb543a6/Pillow-9.0.1.tar.gz
ERROR: Could not install packages due to an EnvironmentError: HTTPSConnectionPool(host='files.pythonhosted.org', port=443): Max retries exceeded with url: /packages/03/a3/f61a9a7ff7969cdef2a6e0383a346eb327495d20d25a2de5a088dbb543a6/Pillow-9.0.1.tar.gz (Caused by NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x74e6d0b8>: Failed to establish a new connection: [Errno -3] Try again'))
ERROR:homeassistant.util.package:Unable to install package pillow==9.0.1: WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x75494ac0>: Failed to establish a new connection: [Errno -3] Try again')': /simple/pillow/
WARNING: Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x75494250>: Failed to establish a new connection: [Errno -3] Try again')': /simple/pillow/
WARNING: Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x75494dd8>: Failed to establish a new connection: [Errno -3] Try again')': /simple/pillow/
WARNING: Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x754949a0>: Failed to establish a new connection: [Errno -3] Try again')': /simple/pillow/
WARNING: Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x754943e8>: Failed to establish a new connection: [Errno -3] Try again')': /simple/pillow/
WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x75494310>: Failed to establish a new connection: [Errno -3] Try again')': /alpine-3.14/armv7/
WARNING: Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x75494400>: Failed to establish a new connection: [Errno -3] Try again')': /alpine-3.14/armv7/
WARNING: Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x75494a78>: Failed to establish a new connection: [Errno -3] Try again')': /alpine-3.14/armv7/
WARNING: Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x754c1910>: Failed to establish a new connection: [Errno -3] Try again')': /alpine-3.14/armv7/
WARNING: Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x75494970>: Failed to establish a new connection: [Errno -3] Try again')': /alpine-3.14/armv7/
ERROR: Could not find a version that satisfies the requirement pillow==9.0.1 (from -c /usr/local/lib/python3.9/site-packages/homeassistant/package_constraints.txt (line 23)) (from versions: none)
ERROR: No matching distribution found for pillow==9.0.1 (from -c /usr/local/lib/python3.9/site-packages/homeassistant/package_constraints.txt (line 23))
INFO:homeassistant.util.package:Attempting install of python-telegram-bot==13.1
INFO:homeassistant.util.package:Attempting install of PySocks==1.7.1
ERROR:homeassistant.util.package:Unable to install package PySocks==1.7.1: WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x753f9250>: Failed to establish a new connection: [Errno -3] Try again')': /simple/pysocks/
WARNING: Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x753f9520>: Failed to establish a new connection: [Errno -3] Try again')': /simple/pysocks/
WARNING: Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x753f93d0>: Failed to establish a new connection: [Errno -3] Try again')': /simple/pysocks/
WARNING: Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x753f9dc0>: Failed to establish a new connection: [Errno -3] Try again')': /simple/pysocks/
WARNING: Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x753f9b68>: Failed to establish a new connection: [Errno -3] Try again')': /simple/pysocks/
WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x753f9268>: Failed to establish a new connection: [Errno -3] Try again')': /alpine-3.14/armv7/
WARNING: Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x753f9e68>: Failed to establish a new connection: [Errno -3] Try again')': /alpine-3.14/armv7/
WARNING: Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x75469a18>: Failed to establish a new connection: [Errno -3] Try again')': /alpine-3.14/armv7/
WARNING: Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x75469c88>: Failed to establish a new connection: [Errno -3] Try again')': /alpine-3.14/armv7/
WARNING: Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x753f9dd8>: Failed to establish a new connection: [Errno -3] Try again')': /alpine-3.14/armv7/
ERROR: Could not find a version that satisfies the requirement PySocks==1.7.1 (from versions: none)
ERROR: No matching distribution found for PySocks==1.7.1
INFO:homeassistant.util.package:Attempting install of mutagen==1.45.1
INFO:homeassistant.util.package:Attempting install of gTTS==2.2.3
INFO:homeassistant.util.package:Attempting install of influxdb==5.3.1
INFO:homeassistant.util.package:Attempting install of influxdb-client==1.24.0
INFO:homeassistant.util.package:Attempting install of HAP-python==4.4.0
INFO:homeassistant.util.package:Attempting install of fnvhash==0.1.0
INFO:homeassistant.util.package:Attempting install of PyQRCode==1.2.1
INFO:homeassistant.util.package:Attempting install of base36==0.1.1
INFO:homeassistant.util.package:Attempting install of ha-ffmpeg==3.0.2
INFO:homeassistant.util.package:Attempting install of PyTurboJPEG==1.6.5
INFO:homeassistant.requirements:Multiple attempts to install pillow==9.0.1 failed, install will be retried after next configuration check or restart
INFO:homeassistant.util.package:Attempting install of fastdotcom==0.0.3
INFO:homeassistant.util.package:Attempting install of RPi.GPIO==0.7.1a4
INFO:homeassistant.util.package:Attempting install of av==8.1.0
INFO:homeassistant.util.package:Attempting install of huawei-lte-api==1.4.18
INFO:homeassistant.util.package:Attempting install of stringcase==1.2.0
INFO:homeassistant.util.package:Attempting install of url-normalize==1.4.1
INFO:homeassistant.util.package:Attempting install of async-upnp-client==0.23.4
INFO:homeassistant.util.package:Attempting install of watchdog==2.1.6
e[1;37mFailed confige[0m
e[1;31mGeneral Errors:e[0m e[31me[31m
- Integration error: logbook - Requirements for image not found: ['pillow==9.0.1'].
- Integration error: frontend - Requirements for image not found: ['pillow==9.0.1'].
- Integration error: panel_iframe - Requirements for image not found: ['pillow==9.0.1'].
- Integration error: person - Requirements for image not found: ['pillow==9.0.1'].
e[0m
e[1;37mSuccessful config (partial)e[0m
