Hello, I’m getting the following errors on update:
Downloading/unpacking homeassistant
Downloading homeassistant-0.36.0-py2.py3-none-any.whl (6.6MB): 6.6MB downloaded
Downloading/unpacking async-timeout==1.1.0 (from homeassistant)
Downloading async_timeout-1.1.0-py3-none-any.whl
Downloading/unpacking voluptuous==0.9.3 (from homeassistant)
Downloading voluptuous-0.9.3.tar.gz
Running setup.py (path:/tmp/pip-build-9u2h0i0m/voluptuous/setup.py) egg_info for package voluptuous
WARNING: Could not locate pandoc, using Markdown long_description.
Downloading/unpacking requests>=2,<3 from https://pypi.python.org/packages/ed/9e/60cc074968c095f728f0d8d28370e8d396fa60afb7582735563cccf223dd/requests-2.12.4-py2.py3-none-any.whl#md5=3989eaeaa2ccad20470afc61710d3498 (from homeassistant)
Downloading requests-2.12.4-py2.py3-none-any.whl (576kB): 576kB downloaded
Downloading/unpacking aiohttp==1.2 (from homeassistant)
Downloading aiohttp-1.2.0.tar.gz (519kB): 519kB downloaded
Running setup.py (path:/tmp/pip-build-9u2h0i0m/aiohttp/setup.py) egg_info for package aiohttp
Compiling aiohttp/_websocket.pyx because it changed.
Cythonizing aiohttp/_websocket.pyx
warning: no previously-included files matching '*.pyc' found anywhere in distribution
warning: no previously-included files found matching 'aiohttp/_multidict.html'
warning: no previously-included files found matching 'aiohttp/_multidict.*.so'
warning: no previously-included files found matching 'aiohttp/_multidict.pyd'
warning: no previously-included files found matching 'aiohttp/_multidict.*.pyd'
warning: no previously-included files found matching 'aiohttp/_websocket.html'
warning: no previously-included files found matching 'aiohttp/_websocket.*.so'
warning: no previously-included files found matching 'aiohttp/_websocket.pyd'
warning: no previously-included files found matching 'aiohttp/_websocket.*.pyd'
no previously-included directories found matching 'docs/_build'
Downloading/unpacking typing>=3,<4 (from homeassistant)
Downloading typing-3.5.3.0.tar.gz (60kB): 60kB downloaded
Running setup.py (path:/tmp/pip-build-9u2h0i0m/typing/setup.py) egg_info for package typing
Downloading/unpacking pytz>=2016.10 (from homeassistant)
Downloading pytz-2016.10-py2.py3-none-any.whl (483kB): 483kB downloaded
Downloading/unpacking pyyaml>=3.11,<4 (from homeassistant)
Downloading PyYAML-3.12.tar.gz (253kB): 253kB downloaded
Running setup.py (path:/tmp/pip-build-9u2h0i0m/pyyaml/setup.py) egg_info for package pyyaml
skipping 'ext/_yaml.c' Cython extension (up-to-date)
Downloading/unpacking jinja2>=2.8 (from homeassistant)
Downloading Jinja2-2.9.4-py2.py3-none-any.whl (274kB): 274kB downloaded
Downloading/unpacking pip>=7.0.0 (from homeassistant)
Downloading pip-9.0.1-py2.py3-none-any.whl (1.3MB): 1.3MB downloaded
Downloading/unpacking setuptools>=0.6b1 from https://pypi.python.org/packages/d3/72/0108eee78038fa8961e2309d4486294b1035968bd940546748b72d309737/setuptools-33.1.0-py2.py3-none-any.whl#md5=fa130e021729eb2ae0bca4f54e56f003 (from voluptuous==0.9.3->homeassistant)
Downloading setuptools-33.1.0-py2.py3-none-any.whl (472kB): 472kB downloaded
Requirement already up-to-date: chardet in /usr/lib/python3/dist-packages (from aiohttp==1.2->homeassistant)
Downloading/unpacking multidict>=2.1.4 (from aiohttp==1.2->homeassistant)
Downloading multidict-2.1.4.tar.gz (101kB): 101kB downloaded
Running setup.py (path:/tmp/pip-build-9u2h0i0m/multidict/setup.py) egg_info for package multidict
Compiling multidict/_multidict.pyx because it changed.
Cythonizing multidict/_multidict.pyx
warning: no previously-included files found matching 'multidict/_multidict.html'
warning: no previously-included files found matching 'multidict/_multidict.*.so'
warning: no previously-included files found matching 'multidict/_multidict.pyd'
warning: no previously-included files found matching 'multidict/_multidict.*.pyd'
Downloading/unpacking yarl>=0.8.1 (from aiohttp==1.2->homeassistant)
Downloading yarl-0.8.1.tar.gz (121kB): 121kB downloaded
Running setup.py (path:/tmp/pip-build-9u2h0i0m/yarl/setup.py) egg_info for package yarl
Error compiling Cython file:
if ch in ALLOWED:
PyUnicode_WriteChar(ret, ret_idx, ch)
ret_idx +=1
continue
tmpbuf = PyUnicode_AsUTF8AndSize(ch, &tmpbuf_size)
yarl/_quoting.pyx:117:15: Assignment to non-lvalue 'tmpbuf'
File "<string>", line 17, in <module>
File "/tmp/pip-build-9u2h0i0m/yarl/setup.py", line 27, in <module>
extensions = cythonize(extensions)
File "/usr/lib/python3/dist-packages/Cython/Build/Dependencies.py", line 840, in cythonize
cythonize_one(*args[1:])
File "/usr/lib/python3/dist-packages/Cython/Build/Dependencies.py", line 959, in cythonize_one
raise CompileError(None, pyx_file)
Cython.Compiler.Errors.CompileError: yarl/_quoting.pyx
Compiling yarl/_quoting.pyx because it changed.
Cythonizing yarl/_quoting.pyx
Complete output from command python setup.py egg_info:
if ch in ALLOWED:
ret_idx +=1
continue
Cleaning up...
Command python setup.py egg_info failed with error code 1 in /tmp/pip-build-9u2h0i0m/yarl
Storing debug log for failure in /home/hass/.pip/pip.log
