Update esphome to 2023.12.x
After update from ESPHOME 2023.11.6 to ESPHOME 2023.12.x, I have the problem that my ESP32-Smart-Display will not compile anymore:
INFO ESPHome 2023.12.5
INFO Reading configuration /config/esphome/smartdisplay-001.yaml…
INFO Detected timezone ‘Europe_Berlin’
WARNING GPIO12 is a strapping PIN and should only be used for I/O with care.
Attaching external pullup/down resistors to strapping pins can cause unexpected failures.
See “Frequently Asked Questions — ESPHome
WARNING GPIO15 is a strapping PIN and should only be used for I/O with care.
See “…same as above…”
WARNING GPIO2 is a strapping PIN and should only be used for I/O with care.
Failed config
touchscreen.xpt2046: [source :479]
platform: xpt2046
spi_id: spi_xpt2046
cs_pin: GPIO33
interrupt_pin: GPIO36
update_interval: 50ms
[report_interval] is an invalid option for [touchscreen.xpt2046]. Did you mean [update_interval]?
report_interval: 1s
threshold: 400
calibration_x_min: 3860
calibration_x_max: 280
calibration_y_min: 340
calibration_y_max: 3860
[swap_x_y] is an invalid option for [touchscreen.xpt2046]. Please check the indentation.
swap_x_y: False
on_touch:
- lambda: |-
ESP_LOGI(“cal”, “x=%d, y=%d, x_raw=%d, y_raw=%0d”,
id(my_xpt2046).x,
id(my_xpt2046).y,
id(my_xpt2046).x_raw,
id(my_xpt2046).y_raw
As I you can see, I have used the same configuration as in the examples. So I don’t see where i did a misstake. Even more when I go back to Version 2023.11.6 then it compiles as expected.
Can anyone help me here? Thanks in advance.
We can’t because you didn’t post your code properly quoted.
See How to help us help you - or How to ask a good question
I have the same problem.
There was a breaking change related to touchscreens that might be affecting you. It’s noted in the changelog for 2023.12.0.
You talk about change, but what does that change tell us?
Yaml esp cannot be compiled if documentation and example are used.
No one in this thread has posted their yaml.
same for me
Edit substitutions for your naming, devices, and passwords here.
By default, this code assumes you have a climate thermostat entity and a separate temperature sensor.
If you want to use the temperature sensor built into your thermostat instead, scroll down to sensor: and use the commented code.
thermostat_entity: Your climate entity that this device will control.
temperature_entity: Your temperature sensor that measures the current temperature in the room. Only used for display purposes.
An experiment by Guy Sie
- GitHub
- Twitter
Based on example ESPHome code by Jonny Bergdahl
- GitHub
- Twitter
- YouTube
ESPHome YAML start
substitutions:
friendly_name: “termostatotouch”
project_name: “Guy Sie.CYD Thermostat Controller”
project_version: “0.1.0”
thermostat_entity: climate.termostato
temperature_entity: sensor.minima_temperatura
esphome:
friendly_name: ${friendly_name}
project:
version: ${project_version}
esp32:
board: esp32dev
framework:
type: arduino
Enable logging
logger:
logs:
component: ERROR
Enable Home Assistant API
api:
encryption:
key: !secret api_key
#“8TQgHaZqzLkm6hG5XNWzaA0VpM9AmtBbMKdZqMmrX04=”
ota:
password: “fd04a0f34cf29179c929ed016adfa21b”
wifi:
ssid: !secret wifi_ssid
Enable fallback hotspot (captive portal) in case wifi connection fails
ap:
ssid: “Termostatotouch Fallback Hotspot”
password: “xuVpbuUlTLK3”
captive_portal:
ESPHome Display related setup
Create a font to use, add and remove glyphs as needed.
font:
  • file:
    type: gfonts
    family: Roboto
    weight: 400
    glyphs: " .,°0123456789COfNAna"
  • file:
    type: gfonts
    family: Roboto
    weight: 400
    glyphs: " .,0123456789NAna"
  • file:
    type: gfonts
    family: Roboto
    weight: 400
    glyphs: “.CTNAurentagoci”
  • file:
    type: gfonts
    family: Material+Symbols+Outlined
    weight: 600
    glyphs: [
    “\U0000f16a”, # mdi-fire
    “\U0000e8ac”, # mdi-power
    “\U0000e145”, # mdi-plus
    “\U0000e15b”, # mdi-minus
Create color scheme
color:
  • id: white
    hex: ffffff
  • id: ha_blue
    hex: 18bcf2
  • id: ha_yellow
    hex: ffd502
  • id: light_orange
    hex: edb597
  • id: mid_orange
    hex: df7d4a
  • id: dark_orange
    hex: bf5922
  • id: light_gray
    hex: e1e1e1
  • id: mid_gray
    hex: c0c0c0
  • id: dark_gray
    hex: 9e9e9e
  • id: blackish
    hex: “212121”
Define the graph
TO DO: Weird behavior of target temperature line. Seems to not display until changed? Figure this out.
graph:
  • id: tempgraph
    duration: 1h
    width: 260
    height: 100
    x_grid: 10min
    y_grid: 2.5
    max_value: 25.0
    min_value: 15.0
    traces:
Display current temperature as a solid blue line
  - sensor: current_temperature
    line_type: SOLID
    line_thickness: 2
    color: ha_blue
Display target temperature as a dashed yellow line
  - sensor: target_temperature
    line_type: DASHED
    line_thickness: 2
    color: ha_yellow
Home Assistant related setup
light:
Set up display backlight
  • platform: monochromatic
    output: backlight_pwm
    name: Display Backlight
    restore_mode: ALWAYS_ON
Set up LED on the back and turn it off by default
  • platform: rgb
    red: led_red
    green: led_green
    blue: led_blue
    restore_mode: ALWAYS_OFF
Set up sensors for thermostat state, current temperature, and target temperature
text_sensor:
  • platform: homeassistant
    entity_id: ${thermostat_entity}
    internal: true
If you wish to use the current temperature from your thermostat, replace the following code block with the commmented code.
    entity_id: ${temperature_entity}
    internal: true
- platform: homeassistant
attribute: current_temperature
internal: true
    attribute: temperature
    internal: true
Set up sensor for LDR (ambient light meter) in V
  • platform: adc
    pin: GPIO34
    update_interval: 1000ms
    entity_category: “diagnostic”
    accuracy_decimals: 3
    internal: true
    filters:
    • sliding_window_moving_average:
      window_size: 10
      send_every: 10
Reports the ambient light in %
TO DO: Could use this to auto adjust brightness of backlight?
Values are based on simple desk testing:
Full dark with backlight turned off: 1.039V
Full dark with backlight turned on: 0.403V
Full light: 0.075V
  • platform: copy
    source_id: board_ldr
    filters:
    • lambda: return min(max((100 - (((x - 0.075) / (1.039 - 0.075)) * 100)), 0.0), 100.0);
      unit_of_measurement: “%”
      accuracy_decimals: 0
Reports the WiFi signal strength/RSSI in dB
  • platform: wifi_signal
    name: “WiFi Signal dB”
    update_interval: 60s
Reports the WiFi signal strength in %
  • platform: copy
    source_id: wifi_signal_db
    name: “WiFi Signal Percent”
    filters:
    • lambda: return min(max(2 * (x + 100.0), 0.0), 100.0);
      unit_of_measurement: “Signal %”
Setup binary sensors for the four areas for touch
binary_sensor:
Minus button to lower target temperature, only active in heating mode
  • platform: touchscreen
    x_min: 20
    x_max: 80
    y_min: 20
    y_max: 60
    on_press:
    • if:
      condition:
      text_sensor.state:
      state: ‘heat’
      then:
      - component.update: cyd
      - homeassistant.service:
      service: climate.set_temperature
      temperature: !lambda |-
      auto target = id(target_temperature).state;
      target -= 0.5;
      return target;
      - logger.log: “Lowering target temperature”
      on_release:
    • component.update: cyd
Plus button to raise target temperature, only active in heating mode
    x_min: 240
    x_max: 300
    y_min: 20
    y_max: 60
    on_press:
    • if:
      condition:
      text_sensor.state:
      state: ‘heat’
      then:
      target += 0.5;
      return target;
      - logger.log: “Increasing target temperature”
      on_release:
Heat button to turn on heating mode
    x_min: 20
    x_max: 80
    y_min: 80
    y_max: 120
    on_press:
    • if:
      condition:
      text_sensor.state:
      state: ‘off’
      then:
      - logger.log: “Turn on heating mode”
      service: climate.turn_on
      on_release:
Off button to turn off heating mode
    x_min: 240
    x_max: 300
    y_min: 80
    y_max: 120
    on_press:
    • if:
      condition:
      text_sensor.state:
      state: ‘heat’
      then:
      - logger.log: “Turn off heating mode”
      service: climate.turn_off
      on_release:
Load images and icons
Not used anymore.
MDI images now loaded as google material design icon font glyphs
Buttons are now made out of shaded filled rectangles
Hardware related setup
Setup SPI for the display. The ESP32-2432S028R uses separate SPI buses for display and touch
spi:
  • id: tft
    clk_pin: GPIO14
    mosi_pin: GPIO13
    miso_pin: GPIO12
  • id: touch
    clk_pin: GPIO25
    mosi_pin: GPIO32
    miso_pin: GPIO39
Setup board power switches
switch:
  • platform: restart
  • platform: shutdown
    name: “$friendly_name shutdown”
  • platform: safe_mode
    name: “$friendly_name restart (Safe Mode)”
Setup a pin to control the backlight
output:
  • platform: ledc
    pin: GPIO21
Setup channels for the red/green/blue of the LED on the back
  • platform: ledc
    pin: GPIO4
    inverted: true
  • platform: ledc
    pin: GPIO16
    inverted: true
  • platform: ledc
    pin: GPIO17
    inverted: true
Set up sound
TO DO: If speaker added to JST, we can use it to provide audio feedback on button presses.
#i2s_audio:
i2s_lrclk_pin: GPIO25
i2s_bclk_pin: GPIO26
#media_player:
- platform: i2s_audio
name: ESPHome I2S Media Player
dac_type: internal
mode: stereo
Setup the ili9xxx platform
Display is used as 240x320 by default so we rotate it to 90°
We print date and time wth the strftime() function, see the ESPHome documentation to
format date and atime to your locale.
display:
  • platform: ili9xxx
    model: ili9341
    spi_id: tft
    cs_pin: GPIO15
    dc_pin: GPIO2
    rotation: 90
Draw interface for touchscreen button control, display of current and target temperature, and graph of current temperature
Only show target temperature and buttons if thermostat is in heating mode
Buttons change shading to look raised or sunken based on heating mode or binary sensor
lambda: |-
  it.fill(id(Color::BLACK));
  if (id(thermostat).state == "heat") {
    if (id(minusbutton).state) {
      it.filled_rectangle(20, 20, 60, 40, id(mid_gray));
      it.filled_rectangle(20, 58, 60, 2, id(light_gray));
      it.filled_rectangle(78, 20, 2, 40, id(light_gray));
      it.filled_rectangle(20, 20, 60, 2, id(dark_gray));
      it.filled_rectangle(20, 20, 2, 40, id(dark_gray));
      it.printf(50, 40, id(icon_font_34), blackish, TextAlign::CENTER, "\U0000e15b");
    else {
      it.filled_rectangle(20, 20, 60, 2, id(light_gray));
      it.filled_rectangle(20, 20, 2, 40, id(light_gray));
      it.filled_rectangle(20, 58, 60, 2, id(dark_gray));
      it.filled_rectangle(78, 20, 2, 40, id(dark_gray));
    if (id(plusbutton).state) {
      it.filled_rectangle(240, 20, 60, 40, id(mid_gray));
      it.filled_rectangle(240, 58, 60, 2, id(light_gray));
      it.filled_rectangle(298, 20, 2, 40, id(light_gray));
      it.filled_rectangle(240, 20, 60, 2, id(dark_gray));
      it.filled_rectangle(240, 20, 2, 40, id(dark_gray));
      it.printf(270, 40, id(icon_font_34), blackish, TextAlign::CENTER, "\U0000e145");
    else {
      it.filled_rectangle(240, 20, 60, 2, id(light_gray));
      it.filled_rectangle(240, 20, 2, 40, id(light_gray));
      it.filled_rectangle(240, 58, 60, 2, id(dark_gray));
      it.filled_rectangle(298, 20, 2, 40, id(dark_gray));
  if (id(thermostat).has_state()) {
      it.printf(160, 10, id(roboto10), TextAlign::TOP_CENTER, "Target");
      it.printf(160, 17, id(roboto40), TextAlign::TOP_CENTER, "%.1f °C", id(target_temperature).state);
    else {
      if (id(thermostat).state == "off") {
        it.printf(160, 17, id(roboto40), TextAlign::TOP_CENTER, "Off");
  if (id(current_temperature).has_state()) {
    it.printf(160, 70, id(roboto10), TextAlign::TOP_CENTER, "Current");
    it.printf(160, 77, id(roboto40), TextAlign::TOP_CENTER, "%.1f °C", id(current_temperature).state);
      it.filled_rectangle(20, 80, 60, 40, id(mid_orange));
      it.filled_rectangle(20, 118, 60, 2, id(light_orange));
      it.filled_rectangle(78, 80, 2, 40, id(light_orange));
      it.filled_rectangle(20, 80, 60, 2, id(dark_orange));
      it.filled_rectangle(20, 80, 2, 40, id(dark_orange));
      it.printf(50, 100, id(icon_font_34), white, TextAlign::CENTER, "\U0000f16a");
    else {
      it.filled_rectangle(20, 80, 60, 40, id(mid_gray));
      it.filled_rectangle(20, 80, 60, 2, id(light_gray));
      it.filled_rectangle(20, 80, 2, 40, id(light_gray));
      it.filled_rectangle(20, 118, 60, 2, id(dark_gray));
      it.filled_rectangle(78, 80, 2, 40, id(dark_gray));
      it.printf(50, 100, id(icon_font_34), blackish, TextAlign::CENTER, "\U0000f16a");
      it.filled_rectangle(240, 80, 60, 40, id(mid_gray));
      it.filled_rectangle(240, 118, 60, 2, id(light_gray));
      it.filled_rectangle(298, 80, 2, 40, id(light_gray));
      it.filled_rectangle(240, 80, 60, 2, id(dark_gray));
      it.filled_rectangle(240, 80, 2, 40, id(dark_gray));
      it.printf(270, 100, id(icon_font_34), blackish, TextAlign::CENTER, "\U0000e8ac");
    else {
      it.filled_rectangle(240, 80, 60, 2, id(light_gray));
      it.filled_rectangle(240, 80, 2, 40, id(light_gray));
      it.filled_rectangle(240, 118, 60, 2, id(dark_gray));
      it.filled_rectangle(298, 80, 2, 40, id(dark_gray));
  else {
    it.printf(160, 70, id(roboto10), TextAlign::TOP_CENTER, "Connecting...");
  it.print(10, 133, id(roboto14), TextAlign::CENTER_LEFT, "25");
  it.print(10, 155, id(roboto14), TextAlign::CENTER_LEFT, "22.5");
  it.print(10, 180, id(roboto14), TextAlign::CENTER_LEFT, "20");
  it.print(10, 205, id(roboto14), TextAlign::CENTER_LEFT, "17.5");
  it.print(10, 227, id(roboto14), TextAlign::CENTER_LEFT, "15");
  it.graph(50, 130, id(tempgraph));
Set up the xpt2046 touch platform
touchscreen:
platform: xpt2046
cs_pin: GPIO33
report_interval: 1s
threshold: 400
swap_x_y: false
For goodness sake please read the instructions!
We can’t read your yaml unless you post it properly. Read this please How to help us help you - or How to ask a good question
i have the same problem
change version from 2023.11.4 to 20223.12.9 , when validate ok but when compiling error :
INFO ESPHome 2023.12.9
INFO Reading configuration /config/esphome/esphome-web-5d0c50.yaml…
Failed config
touchscreen.xpt2046: [source :296]
platform: xpt2046
spi_id: touch
report_interval: 1s
threshold: 400
calibration_x_min: 3895
calibration_x_max: 354
calibration_y_min: 25
calibration_y_max: 3780
swap_x_y: True
cs_pin: 33
on_touch:
- lambda: |-
id(my_touchscreen).x,
id(my_touchscreen).y,
id(my_touchscreen).x_raw,
id(my_touchscreen).y_raw
my YAML.
esphome:
friendly_name: GRANDISPLAY
esp32:
board: esp32dev
framework:
type: arduino
Enable logging
logger:
api:
encryption:
key: “F66z05Jb7wVQvAF8y2qSFU78ZMEGzak60JzTACbxG4w=”
ota:
wifi:
ap:
ssid: “Esphome-Web-5D0C50”
password: “22olCREelwCO”
manual_ip:
static_ip: 172.25.0.78
gateway: 172.25.0.1
subnet: 255.255.255.0
dns1: 172.25.0.4
dns2: 8.8.8.8
power_save_mode: HIGH
captive_portal:
web_server:
port: 80
time:
#- platform: homeassistant
  • platform: sntp
    timezone: Europe/Rome
    servers: 172.25.0.4
spi:
  • id: lcd
    clk_pin: GPIO14
    mosi_pin: GPIO13
    miso_pin: GPIO12
  • id: touch
    clk_pin: GPIO25
    mosi_pin: GPIO32
    miso_pin: GPIO39
i2c:
sda: GPIO27
scl: GPIO22
scan: true
color:
  • id: my_red
    red: 100%
    green: 0%
    blue: 0%
  • id: my_orange
    red: 100%
    green: 50%
    blue: 0%
  • id: my_yellow
    red: 100%
    green: 100%
    blue: 0%
  • id: my_green
    red: 30%
    green: 100%
    blue: 0%
  • id: my_blue
    red: 0%
    green: 0%
    blue: 100%
  • id: my_teal
    red: 0%
    green: 100%
    blue: 100%
  • id: my_gray
    red: 70%
    green: 70%
    blue: 70%
  • id: my_white
    red: 100%
    green: 100%
    blue: 100%
font:
  • file: “helvetica.ttf”
image:
  • file: “power-off-button.png”
binary_sensor:
  • platform: status
    x_min: 150
    x_max: 230
    y_min: 0
    y_max: 80
    x_min: 40
    x_max: 100
    y_min: 0
    y_max: 80
text_sensor:
  • platform: template
    name: Uptime Human Readable
    icon: mdi:clock-start
    internal: False
    entity_id: sensor.gridpower_power
    internal: True
    entity_id: sensor.termometro_temperature
    internal: True
    entity_id: sensor.mysens_temperatura
    internal: True
  • platform: wifi_info
    ip_address:
    name: ESP IP Address
  • platform: uptime
    internal: True
    update_interval: 60ms
    on_raw_value:
    then:
    - text_sensor.template.publish:
    state: !lambda |-
    int seconds = round(id(uptime_sensor).raw_state);
    int days = seconds / (24 * 3600);
    seconds = seconds % (24 * 3600);
    int hours = seconds / 3600;
    seconds = seconds % 3600;
    int minutes = seconds / 60;
    seconds = seconds % 60;
    return (
    ("Uptime ") +
    (days ? to_string(days) + "d " : “”) +
    (hours ? to_string(hours) + "h " : “”) +
    (minutes ? to_string(minutes) + "m " : “”) +
    (to_string(seconds) + “s”)
    ).c_str();
    name: “WiFi Signal Sensor”
    internal: True
    update_interval: 120s
display:
  • platform: ili9xxx
    model: ILI9342
    spi_id: lcd
    cs_pin: 15
    dc_pin: 2
    rotation: 90
    lambda: |-
    int hs = it.get_width() / 2; // Horizontal Spacing = text data horizontal center point
    int hq = it.get_width() / 4; // text data horizontal center for two vertical lines
    int vs = it.get_height() / 8; // Vertical Center = text data vertical center point = how many lines
    int line_gap = 21; // distance of line from center of data text
    it.rectangle(0, 0, it.get_width(), it.get_height(), id(my_white));
    it.rectangle(0, 20, it.get_width(), it.get_height(), id(my_white));
    it.strftime(5, 5, id(helvetica_12), id(my_white), TextAlign::TOP_LEFT, “%H:%M:%S”, id(esptime).now());
    it.print(hs, 5, id(helvetica_12), id(my_white), TextAlign::TOP_CENTER, “${GRIDx}”); //print title
    if (id(system_status).state) {
    it.print(it.get_width()-5, 5, id(helvetica_12), id(my_green), TextAlign::TOP_RIGHT, “Online”);
    else {
    it.print(it.get_width()-5, 5, id(helvetica_12), id(my_red), TextAlign::TOP_RIGHT, “Offline”);
    it.line(0, it.get_height()-20, it.get_width(), it.get_height()-20, id(my_white)); // line across bottom above footer text
    it.printf(5, it.get_height()-3, id(helvetica_12), id(my_gray), TextAlign::BOTTOM_LEFT, “%s”, id(uptime_human).state.c_str());
    it.printf(hs, it.get_height()-3, id(helvetica_12), id(my_gray), TextAlign::BOTTOM_CENTER, “%.0fdBm”, id(wifi_signal_sensor).state);
    it.printf(it.get_width()-5, it.get_height()-3, id(helvetica_12), id(my_gray), TextAlign::BOTTOM_RIGHT, “%s”, id(ip_address).state.c_str());
    it.image(hq - 25, 40, id(on_off_button));
    it.image(3*hq - 25, 40, id(radio));
    it.line(0, vs * 3, it.get_width(), vs * 3, id(my_white));
    it.print(hs, vs * 3 + line_gap, id(helvetica_24), id(my_white), TextAlign::CENTER, “DOMOTICS HOME”);
    it.line(0, vs * 4, it.get_width(), vs * 4, id(my_white));
    static bool show = false;
    if (show)
    it.print(hq, vs * 5, id(helvetica_16), id(my_white), TextAlign::CENTER, “GRIDx”);
    it.printf(3hq, vs * 5, id(helvetica_16), id(my_white), TextAlign::CENTER, “: %s W.”, id(alarm_state).state.c_str());
    it.print(hq, vs * 6, id(helvetica_16), id(my_white), TextAlign::CENTER, “TEMP EXT.”);
    it.printf(3
    hq, vs * 6, id(helvetica_16), id(my_white), TextAlign::CENTER, “: %s G.”, id(tpmext_state).state.c_str());
    it.print(hq, vs * 7, id(helvetica_16), id(my_white), TextAlign::CENTER, “TEMP INT.”);
    it.printf(3*hq, vs * 7, id(helvetica_16), id(my_white), TextAlign::CENTER, “: %s G.”, id(tpmint_state).state.c_str());
    show = !show;
Define pins for backlight display and back LED1
output:
  • platform: ledc
    pin: GPIO21
  • platform: ledc
    pin: GPIO4
    inverted: true
  • platform: ledc
    pin: GPIO16
    inverted: true
  • platform: ledc
    pin: GPIO17
    inverted: true
Define a monochromatic, dimmable light for the backlight
light:
    output: former_led_pin
    name: “Display Backlight”
  • platform: rgb
    red: output_red
    green: output_green
    blue: output_blue
touchscreen:
platform: xpt2046
spi_id: touch
report_interval: 1s
threshold: 400
swap_x_y: True
cs_pin: 33
on_touch:
- lambda: |-
Exposed switches.
switch:
  • platform: restart
Failed config
platform: xpt2046
spi_id: touch
report_interval: 1s
threshold: 400
swap_x_y: True
cs_pin: 33
on_touch:
- lambda: |-
my YAML.
esphome:
esp32:
board: esp32dev
framework:
type: arduino
Enable logging
logger:
api:
encryption:
ota:
wifi:
ap:
manual_ip:
gateway: 172.25.0.1
dns1: 172.25.0.4
dns2: 8.8.8.8
captive_portal:
web_server:
port: 80
time:
  • platform: sntp
    servers: 172.25.0.4
spi:
  • id: lcd
    clk_pin: GPIO14
    mosi_pin: GPIO13
    miso_pin: GPIO12
  • id: touch
    clk_pin: GPIO25
    mosi_pin: GPIO32
    miso_pin: GPIO39
i2c:
sda: GPIO27
scl: GPIO22
scan: true
color:
  • id: my_red
    red: 100%
    green: 0%
    blue: 0%
  • id: my_orange
    red: 100%
    green: 50%
    blue: 0%
  • id: my_yellow
    red: 100%
    green: 100%
    blue: 0%
  • id: my_green
    red: 30%
    green: 100%
    blue: 0%
  • id: my_blue
    red: 0%
    green: 0%
    blue: 100%
  • id: my_teal
    red: 0%
    green: 100%
    blue: 100%
  • id: my_gray
    red: 70%
    green: 70%
    blue: 70%
  • id: my_white
    red: 100%
    green: 100%
    blue: 100%
font:
image:
binary_sensor:
  • platform: status
    x_min: 150
    x_max: 230
    y_min: 0
    y_max: 80
    x_min: 40
    x_max: 100
    y_min: 0
    y_max: 80
text_sensor:
    internal: False
    internal: True
    internal: True
    internal: True
    ip_address:
  • platform: uptime
    internal: True
    on_raw_value:
    then:
    state: !lambda |-
    return (
    ("Uptime ") +
    ).c_str();
    internal: True
display:
  • platform: ili9xxx
    model: ILI9342
    spi_id: lcd
    cs_pin: 15
    dc_pin: 2
    rotation: 90
    lambda: |-
    else {
    if (show)
    it.printf(3
    show = !show;
output:
  • platform: ledc
    pin: GPIO21
  • platform: ledc
    pin: GPIO4
    inverted: true
  • platform: ledc
    pin: GPIO16
    inverted: true
  • platform: ledc
    pin: GPIO17
    inverted: true
light:
  • platform: rgb
    red: output_red
    green: output_green
    blue: output_blue
touchscreen:
platform: xpt2046
spi_id: touch
report_interval: 1s
threshold: 400
swap_x_y: True
cs_pin: 33
on_touch:
- lambda: |-
Exposed switches.
switch:
  • platform: restart
Please:
