Ubuntu server - Docker - HA
I have done 3-5 updates, by just pressing the update button and it worked just fine. Now I get errors.
Now getError: Unknown Error, see logs!
20-04-23 13:39:13 ERROR (SyncWorker_13) [supervisor.docker.interface] Can’t install homeassistant/qemux86-64-homeassistant:0.108.8 -> 500 Server Error: Internal Server Error (“Get https://registry-1.docker.io/v2/: dial tcp: lookup registry-1.docker.io: Temporary failure in name resolution”).
20-04-23 13:39:13 WARNING (MainThread) [supervisor.homeassistant] Update Home Assistant image fails
20-04-23 13:44:55 ERROR (SyncWorker_8) [supervisor.docker.interface] Can’t install homeassistant/amd64-hassio-supervisor:219 -> 500 Server Error: Internal Server Error (“Get https://registry-1.docker.io/v2/: dial tcp: lookup registry-1.docker.io: Temporary failure in name resolution”).
20-04-23 13:44:55 ERROR (MainThread) [supervisor.supervisor] Update of Supervisor fails!
What is going on?
for some reason I have 2 Docker images
but container is created based on 1
