I am trying to update my Hass.IO install and running in to the following error after pressing the update button in Hass.IO pane.
19-11-25 19:01:38 INFO (MainThread) [hassio.updater] Fetch update data from https://version.home-assistant.io/stable.json
19-11-25 19:08:18 INFO (MainThread) [hassio.host.info] Update local host information
19-11-25 19:08:18 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
19-11-25 19:08:19 INFO (MainThread) [hassio.host.services] Update service information
19-11-25 19:08:19 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
19-11-25 19:08:19 INFO (MainThread) [hassio.host.network] Update local network DNS information
19-11-25 19:08:19 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/NetworkManager/DnsManager
19-11-25 19:14:13 INFO (MainThread) [hassio.homeassistant] Update Home Assistant to version 0.102.2
19-11-25 19:14:13 INFO (SyncWorker_16) [hassio.docker.interface] Update image homeassistant/raspberrypi3-homeassistant:0.101.2 to homeassistant/raspberrypi3-homeassistant:0.102.2
19-11-25 19:14:13 INFO (SyncWorker_16) [hassio.docker.interface] Pull image homeassistant/raspberrypi3-homeassistant tag 0.102.2.
19-11-25 19:15:04 ERROR (SyncWorker_16) [hassio.docker.interface] Can't install homeassistant/raspberrypi3-homeassistant:0.102.2 -> 404 Client Error: Not Found ("no such image: homeassistant/raspberrypi3-homeassistant:0.102.2: No such image: homeassistant/raspberrypi3-homeassistant:0.102.2").
19-11-25 19:15:04 WARNING (MainThread) [hassio.homeassistant] Update Home Assistant image fails
I notice this error earlier in the log but, haven’t found much to show what this means…
19-11-25 16:59:25 WARNING (MainThread) [hassio.dbus.rauc] Host has no rauc support. OTA updates have been disabled.
I am using a Raspberry Pi 3 with Buster as the host and supervisor version 192.
Thanks,
Devan
