Continuing the discussion from Feedreader update time:
except that we can’t update any of the event entities like this
disabling polling on the feedreader events to prevent too frequent polling.
and then what?
the default update_entity service is futile here
seems the only way (but not at all user friendly or safe) is to leave the polling enabled on the integration. and then
programmatically disable, enable for a single check and disable, the device, using the Spook services.
ofc, we can also do that manually, but that is even more of a hassle.
edit
heck no, disabling the device does Not stop the integration from retrieving it;s feeds. Next try: disable the integration completely using Spook
automation:
- id: poll_feedreader_on_demand
triggers:
- trigger: time_pattern
hours: '/3'
- trigger: time
at:
- '9:00'
- '12:00'
- '19:00'
conditions: []
actions:
- action: homeassistant.enable_config_entry
config_entry_id: &config_entries
- 01JF0489EBBM4Y1DMKQ296D1SP
- 01JF2C4CRNFS61EEVXDHXZQT6A
- delay: 20
- action: homeassistant.disable_config_entry
config_entry_id: *config_entries
not even sure the listed config_entries work in those actions, raises no error, but UI does not support it
Nope, seems it does not work.
so we must do:
config_entry_id: 01JF0489EBBM4Y1DMKQ296D1SP
config_entry_id: 01JF2C4CRNFS61EEVXDHXZQT6A
- etc etc
Conclusion must be we Can Not control Feedreader updating, other than creating convoluted automations using Spooky custom integrations…
