I have a Yellow HA and I use the internal Silicon Labs radio. The FW is in 7.3.1.0.
I wanted to update to 7.4.0.0. I followed the instructions on the official page Flash Silicon Labs radio firmware manually Flash Silicon Labs radio firmware manually · NabuCasa/silabs-firmware Wiki · GitHub, everything went well, the update was done normally without error. I even restarted a second time to be sure that it was up to date and I was able to confirm that it was the case since after the test, it did not want to do an update again since the version 7.4.0.0 was already installed.
I rebooted the Yellow box.
Then I went to see the bridge version in MQTT and there I noticed that it was still in 7.3.1.0 (see screenshot below).
I did the whole procedure again and it tells me that it is indeed 7.4.0.0 that is installed.
My question is therefore: am I looking in the right place? Was this update done correctly or not?
Any idea what I could do?
Thanks for your help.
