Hey @Romquenin@Pippyn how are you doing? Apologies for reopening this thread now that it is closed! Could you please let me know where I can find the script you are talking about? I believe it is required to make it work and I cannot find it anywhere
Over the years this has changed.
Youâll need to make a folder in your custom_components folder and name it like we used to name the file. e.i. fixer_hour or something
Thanks for your response. But it seems I am facing the issue described here Fixer.io exchange rates fails to load where the API Key generated by the new site API Layer that owns Fixer/io is no longer valid with this integration.
TLDR, saw the Fixer/io component yesterday. It didnât work out of the box and saw then your thread and the references to those files. I thought these files were indeed required to make it work, but it seems they are not required. It should work fine just by adding the sensor config and having a correct API Key.
Anyway, I have tried what you mentioned and it didnât work either:
Platform error sensor.fixer_hour - Integration âfixer_hourâ not found.
Folder: /root/config/custom_components/fixer_hour â dropped in here the three files
