Does anyone know how often the energy panel updates it’s values ?
Second, can I change that value ?
Hourly, at 12 minutes past the hour, and no it is not user configurable.
Hi Tom,
Thank you.
Do you know why?
I mean what’s wrong with updating every minute or so ?
Is there a feature request about this ?
Probably something to do with the fact that the values are calculated from LTS (long term statistics) for display and the minimum display resolution of the energy dashboard is one hour so there’s not much point calculating any shorter values.
You have the entities available that you used in the energy dashboard so you can always check/display them in your own dashboard for their current values.
Correct, I use these for my gauge cards and utility meters.
Thanks.
