Update frequency sensor template
i use this template to round my temperature sensor from 0.01 °C to 0.1 °C
value_template: "{{ (states('sensor.rm4_temperature') | round(1)) }}"
it works fine, but the template sensor rarely updates,
i see the original broadlink sensor updating every few minutes, the template doesn’t update very often,
template_update
why is that?
can i change the update frequency?
The Template Sensor is evaluated each time sensor.rm4_temperature changes state. However, the Template Sensor’s value will be updated only if it changes.
Let’s say these are values of sensor.rm4_temperature every 15 seconds:
18.48
18.42
18.47
18.40
18.43
The Template Sensor’s value will be at 18.5 for the first one and then remain unchanged for all others because none of them, when rounded, are different from 18.5.
that makes sense, :man_facepalming:
thx for the fast aswer
You’re welcome!
Please consider marking my post (above) with the Solution tag. It will automatically place a check-mark next to the topic’s title which signals to other users that this topic has an accepted solution. This helps others find answers to similar questions.
