i just update my HA from 0.68 to 0.68.1 version
and now asking google assistant to switch light on is not working any more…
Normally i have to check if http server is working and it was not working, so im using this comnmand (sudo setcap ‘cap_net_bind_service=+ep’ /usr/bin/python3.5) , because im using virtual environment in hassbian…this error is old at least one year now…
but this time is not helping me …
I did see that IFTTT.com webhooks api had different api key ( i did not change it and 10 hrs before i update HA to 0.68.1 version, everything was working…
So i change ifttt key in configuration… so is o.k.
http server is working…i did check /description.xml is responding… ifttt.com key is correct ( using webhooks ).
configuration file is o.k. i did not change it and i check with backup and i tried to change it too with old backup, but nothing…
ifttt:
key: xxxxxxxxxxxxxxxxxx
tts:
so what else should i try? Or is this update that is not working?
Logfile is not showing nothing…
when i ask google assistant to turn on lights, google assistant reponds and in IFTTT.com i can see that applet run but light will not switch on… i have to use webpage from overview.
yes,
it is like this… with HA you have to work all the time, it is nightmare everytime you update…you dont know what will work and whot will NOT work…
in last year i spend relly lot of time setting up, and now i have to do it one more time., till; next update…
it is free, you think, but it is a lot of spear time to set it up…and there will be some new update, biggert one one, that will force you to make changes etc etc etc…
I haven’t really found that.
There was an issue with some of my Xiaomi switches which were fixed in hotfixes and I just waited it out and they changed Google Assistant integration a few releases back as well but nothing critical broke for me.
I guess we still haven’t made version 1 yet and it’s all still in beta but I’ve found it pretty stable to be honest.
and one very important thing… now i’m googling for and hour and there are no documents how to set up this cloud…
there are only few forum posts…
So disappointed that i update today HA. all night i will need to make it work like before…
not sure if i will be able to make it work with this home cloud thing…
thank you for reply
you help me make more work c:)))
by
kikan
It is very hard to set up home assistant cloud !!!
so much more work than ifttt.com
going back to version 0.60 HA and i will never ever update it…
home assistant cloud is very difficult and strange to set up, because google actions is so strange and it ask you so much things and documents and pictures and emails and privacy etc etc etc…
