Continuing the discussion from Update 2022.6.7 failing:
I am having this problem. My installation is on a virtualbox virtual machine running on linux installed on a 2013 mac mini. It fails half way through installing and just shows that the update is still available. I usually get the 404 error in supervisor logs, that is when it doesn’t crash and restart during update. For this reason I went ahead and increased the virtual disk space for the virtual machine to 256Gb. Still does not work. I tried updating through the command line and that also fails. Did someone here get it working? what ended up being the problem?
I read something about the ha os not recognizing that the size of the virtual disk has been increased… (I increased the disk after updating the ha os), how could I check this?
Any other ideas?
Thank you!
k
EDIT: also the system shows up as healthy .
