I have a database with MariaDB, the size is around 51G.
I updated 8h ago and this morning the message the Database migration is in progress has change to can’t migrate the DB so I look on the logs and I see this:
Enregistreur: homeassistant.components.recorder.core
Source: components/recorder/core.py:988
intégration: Recorder (documentation, problèmes)
S'est produit pour la première fois: 11:14:22 (1 occurrences)
Dernier enregistrement: 11:14:22
Error during schema migration
File "/usr/src/homeassistant/homeassistant/components/recorder/core.py", line 988, in _migrate_schema
new_schema_status = migrator(
File "/usr/src/homeassistant/homeassistant/components/recorder/migration.py", line 335, in migrate_schema_live
schema_status = _migrate_schema(
File "/usr/src/homeassistant/homeassistant/components/recorder/migration.py", line 301, in _migrate_schema
_apply_update(instance, hass, engine, session_maker, new_version, start_version)
File "/usr/src/homeassistant/homeassistant/components/recorder/util.py", line 703, in wrapper
job(instance, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/components/recorder/migration.py", line 712, in _apply_update
migrator_cls(instance, hass, engine, session_maker, old_version).apply_update()
File "/usr/src/homeassistant/homeassistant/components/recorder/migration.py", line 758, in apply_update
self._apply_update()
File "/usr/src/homeassistant/homeassistant/components/recorder/migration.py", line 1492, in _apply_update
_modify_columns(
File "/usr/src/homeassistant/homeassistant/components/recorder/migration.py", line 559, in _modify_columns
with session_scope(session=session_maker()) as session:
File "/usr/local/lib/python3.12/contextlib.py", line 144, in __exit__
next(self.gen)
File "/usr/src/homeassistant/homeassistant/helpers/recorder.py", line 104, in session_scope
session.commit()
File "/usr/local/lib/python3.12/site-packages/sqlalchemy/orm/session.py", line 2017, in commit
trans.commit(_to_root=True)
File "<string>", line 2, in commit
File "/usr/local/lib/python3.12/site-packages/sqlalchemy/orm/state_changes.py", line 139, in _go
ret_value = fn(self, *arg, **kw)
File "/usr/local/lib/python3.12/site-packages/sqlalchemy/orm/session.py", line 1309, in commit
trans.commit()
File "/usr/local/lib/python3.12/site-packages/sqlalchemy/engine/base.py", line 2629, in commit
self._do_commit()
File "/usr/local/lib/python3.12/site-packages/sqlalchemy/engine/base.py", line 2734, in _do_commit
self._connection_commit_impl()
File "/usr/local/lib/python3.12/site-packages/sqlalchemy/engine/base.py", line 2705, in _connection_commit_impl
self.connection._commit_impl()
File "/usr/local/lib/python3.12/site-packages/sqlalchemy/engine/base.py", line 1146, in _commit_impl
self._handle_dbapi_exception(e, None, None, None, None)
File "/usr/local/lib/python3.12/site-packages/sqlalchemy/engine/base.py", line 2356, in _handle_dbapi_exception
raise exc_info[1].with_traceback(exc_info[2])
File "/usr/local/lib/python3.12/site-packages/sqlalchemy/engine/base.py", line 1144, in _commit_impl
self.engine.dialect.do_commit(self.connection)
File "/usr/local/lib/python3.12/site-packages/sqlalchemy/engine/base.py", line 585, in connection
return self._revalidate_connection()
File "/usr/local/lib/python3.12/site-packages/sqlalchemy/engine/base.py", line 677, in _revalidate_connection
self._invalid_transaction()
File "/usr/local/lib/python3.12/site-packages/sqlalchemy/engine/base.py", line 667, in _invalid_transaction
raise exc.PendingRollbackError(
sqlalchemy.exc.PendingRollbackError: Can't reconnect until invalid transaction is rolled back. Please rollback() fully before proceeding (Background on this error at: https://sqlalche.me/e/20/8s2b)
so I restart HA and the message is back at:
Database upgrade in progress
System performance will temporarily degrade during the database upgrade. Do not power down or restart the system until the upgrade completes. Integrations that read the database, such as logbook, history, and statistics may return inconsistent results until the upgrade completes. This notification will be automatically dismissed when the upgrade completes.
I will see in +/- 15h if I get still the issue, did I am the only on has got this issue with the migration?
Thank
