I have tried to update today and got this error:
19-09-08 08:00:45 INFO (SyncWorker_32) [hassio.docker.interface] Update image homeassistant/odroid-xu-homeassistant:0.98.3 to homeassistant/odroid-xu-homeassistant:0.98.4
19-09-08 08:00:45 INFO (SyncWorker_32) [hassio.docker.interface] Pull image homeassistant/odroid-xu-homeassistant tag 0.98.4.
19-09-08 08:04:29 ERROR (SyncWorker_32) [hassio.docker.interface] Can't install homeassistant/odroid-xu-homeassistant:0.98.4 -> 404 Client Error: Not Found ("no such image: homeassistant/odroid-xu-homeassistant:0.98.4: No such image: homeassistant/odroid-xu-homeassistant:0.98.4").
19-09-08 08:04:29 WARNING (MainThread) [hassio.homeassistant] Update Home Assistant image fails
19-09-08 08:04:29 ERROR (MainThread) [asyncio] Task exception was never retrieved
future: <Task finished coro=<process_lock.<locals>.wrap_api() done, defined at /usr/src/hassio/hassio/utils/__init__.py:20> exception=HomeAssistantUpdateError()>
File "/usr/src/hassio/hassio/utils/__init__.py", line 29, in wrap_api
return await method(api, *args, **kwargs)
File "/usr/src/hassio/hassio/homeassistant.py", line 337, in update
raise HomeAssistantUpdateError()
hassio.exceptions.HomeAssistantUpdateError
Any suggestions, why it is happening.
