My HA (RPi, Docker) runs perfectly with version 2022.5.5.
All later updates are not executable (tested up to 2022.7.0b5), the start is aborted immediately, without any further message. Docker status: Exited (100)
I tried with an empty /config directory, but not even the default files are created.
I minimised the call to the most necessary, which runs without problems with 2022.5.5: docker run --init -d --name="xxl" --net=host homeassistant/home-assistant:2022.6.7
If you run Home Assistant Container in Docker (e.g., using Portainer, Docker (Compose), QNAP, and others), please make sure you are not specifying an init process.
This can be an init configuration option in your Docker management tools or Docker Compose, or the --init command line flag on the raw Docker command. These should NOT be set, as Home Assistant ships with the S6 init system.
