Update `Home Assistant Supervisor` on HA Yellow
Hi, I’m trying to update an unused “Home Assistant Yellow” for ~2 years but I get
Failed to call service update/install. Error updating Home Assistant Supervisor: Update of Supervisor failed: Can't install ghcr.io/home-assistant/aarch64-hassio-supervisor:2026.04.0: 404 Client Error for http+docker://localhost/v1.41/images/ghcr.io/home-assistant/aarch64-hassio-supervisor:2026.04.0/json: Not Found ("no such image: ghcr.io/home-assistant/aarch64-hassio-supervisor:2026.04.0: No such image: ghcr.io/home-assistant/aarch64-hassio-supervisor:2026.04.0")
I can’t use SSH because I’m not allowed to install add-ons because of the outdated Home Assistant Supervisor. The installed version of Home Assistant Supervisor is 2024.06.2.
What to do?
Package aarch64-hassio-supervisor · GitHub seems to exist because I can reach it from my laptop.
I’ve tried multiple times. Also tried to disable ipv6 and change dns to 8.8.8.8.
If it’s two years old why not rebuild from scratch?
I’m in a similar situation.
My HA Supervisor failed to update because it gets a 404 client error when trying to pull the 2026.04.0 docker image.
I cannot access the host using ssh, my only way in was the ssh/terminal module and now that supervisor is failing the update, all addon features have disabled and I can’t get into the box anymore.
Sure, that’s one option. Thanks for the link :slight_smile:
Right? I’m only interested in fighting a prob so much :joy:
For the other guy @LongBeachHXC have you retried the update since it may have been transient?
I did a reset but it fails to start again. It’s stuck on Preparing Home Assistant and seems to be a similar problem
26-04-26 09:31:49 ERROR (SyncWorker_2) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/yellow-homeassistant:2026.4.4: 404 Client Error for http+docker://localhost/v1.41/images/ghcr.io/home-assistant/yellow-homeassistant:2026.4.4/json: Not Found ("no such image: ghcr.io/home-assistant/yellow-homeassistant:2026.4.4: No such image: ghcr.io/home-assistant/yellow-homeassistant:2026.4.4")
and
awesomeversion.exceptions.AwesomeVersionCompareException: Can't compare <unknown landingpage> and <CalVer 2023.3.4>
26-04-26 09:32:46 ERROR (MainThread) [aiohttp.server] Error handling request
  File "/usr/local/lib/python3.11/site-packages/aiohttp/web_protocol.py", line 433, in _handle_request
    resp = await request_handler(request)
  File "/usr/local/lib/python3.11/site-packages/aiohttp/web_app.py", line 504, in _handle
    resp = await handler(request)
  File "/usr/local/lib/python3.11/site-packages/aiohttp/web_middlewares.py", line 117, in impl
    return await handler(request)
  File "/usr/src/supervisor/supervisor/api/middleware/security.py", line 185, in block_bad_requests
  File "/usr/src/supervisor/supervisor/api/middleware/security.py", line 201, in system_validation
  File "/usr/src/supervisor/supervisor/api/middleware/security.py", line 268, in token_validation
  File "/usr/src/supervisor/supervisor/api/middleware/security.py", line 278, in core_proxy
    or self.sys_homeassistant.version >= _CORE_VERSION
  File "/usr/local/lib/python3.11/site-packages/awesomeversion/awesomeversion.py", line 205, in __ge__
    return self.__eq__(compareto) or self.__gt__(compareto)
  File "/usr/local/lib/python3.11/site-packages/awesomeversion/awesomeversion.py", line 192, in __gt__
    raise AwesomeVersionCompareException(
Full logs available at Download observer_2026-04-26T07-32-44.345Z.log | LimeWire
