Update Honeywell (somecomfort) dependency to v0.4.1
There was a filename issue with somecomfort 0.3.2 (used for the Honeywell climate component in Home Assistant). The filename issue has been resolved with somecomfort version 0.4.1. However, Home Assistant is still looking for 0.3.2 as the dependency.
Can you please update Home Assistant to use somecomfort 0.4.1 as the dependency for the Honeywell climate component?
Thanks!
You should actually open an issue on Github for this. :wink:
Thanks, will do.
