What does “docker rm homeassistant” actually do ? Does configurations remain ?
It removes the container, but not the data.
However, you should use a Compose file instead of the docker run
command. Then your updates are simpler:
docker compose pull homeassistant
docker compose up -d homeassistant
Awesome, thank you
