Hi, I have an automation (see below) with two triggers defined, “state > input_boolean > on” and “event > telegram_command > command”, the automation works and triggers as expected via either trigger, what I would like to do is update the state of the input_boolean when the automation is triggered via the telegram_command without re-triggering the automation, is this possible?
Automation:-
- id: '3454366499090'
alias: Show Cameras On Vizio TV
initial_state: true
- platform: state
entity_id: input_boolean.cameras_on_vizio
to: 'on'
- platform: event
event_type: telegram_command
event_data:
command: '/camsyson'
- service: script.turn_on
entity_id: script.cameras_on_vizio
Thanks.
