Update_interval invalid option on cse7766 - Athom Smart Plug v2 - Updated for post ESPHome 2024.2.0
Incase someone runs into this. Here is an updated template post ESPHome Update 2024.2.0
substitutions:
  friendly_name: "Smart Plug V2"
  room: ""
  device_description: "athom smart plug v2"
  project_name: "Athom Technology.Smart Plug V2"
  project_version: "2.0"
  relay_restore_mode: RESTORE_DEFAULT_OFF
esphome:
  friendly_name: "${friendly_name}"
  name_add_mac_suffix: true
  project:
    version: "${project_version}"
esp8266:
  board: esp8285
  restore_from_flash: true
preferences:
  flash_write_interval: 1min
api:
ota:
logger:
  baud_rate: 0
mdns:
  disabled: false
web_server:
  port: 80
wifi:
  ap: {} # This spawns an AP with the device name and mac address with no password.
captive_portal:
dashboard_import:
  package_import_url: github://athom-tech/athom-configs/athom-smart-plug-v2.yaml
uart:
  rx_pin: RX
  baud_rate: 4800
globals:
  - id: total_energy
    type: float
    restore_value: yes
    initial_value: '0.0'
binary_sensor:
  - platform: status
  - platform: gpio
    pin:
      number: 5
      mode: INPUT_PULLUP
      inverted: true
    disabled_by_default: true
    on_multi_click:
      - timing:
          - ON for at most 1s
          - OFF for at least 0.2s
        then:
          - switch.toggle: relay
      - timing:
          - ON for at least 4s
        then:
          - button.press: Reset
  - platform: uptime
  - platform: wifi_signal
    update_interval: 60s
  - platform: cse7766
    current:
      filters:
          - lambda: if (x < 0.060) return 0.0; else return x;   #For the chip will report less than 3w power when no load is connected
          - throttle: 30s
    voltage:
      filters:
        - throttle: 30s
    power:
      filters:
          - lambda: if (x < 3.0) return 0.0; else return x;    #For the chip will report less than 3w power when no load is connected
          - throttle: 30s
    energy:
      unit_of_measurement: kWh
      filters:
        # Multiplication factor from W to kW is 0.001
        - multiply: 0.001
        - throttle: 10s
      on_value:
        then:
          - lambda: |-
              static float previous_energy_value = 0.0;
              float current_energy_value = id(energy).state;
              id(total_energy) += current_energy_value - previous_energy_value;
              previous_energy_value = current_energy_value;
    device_class: "energy"
    state_class: "total_increasing"
    icon: "mdi:lightning-bolt"
    accuracy_decimals: 3
    lambda: |-
      return id(total_energy);
    update_interval: 10s
  - platform: total_daily_energy
    name: "Total Daily Energy"
    restore: true
    power_id: power_sensor
    filters:
      - multiply: 0.001
button:
  - platform: factory_reset
    name: "Restart with Factory Default Settings"
  - platform: safe_mode
    internal: false
    internal: false
switch:
  - platform: gpio
    pin: GPIO12
    restore_mode: ${relay_restore_mode}
light:
  - platform: status_led
    pin:
      inverted: true
      number: GPIO13
text_sensor:
  - platform: wifi_info
    ip_address:
    ssid:
    mac_address:
time:
  - platform: sntp
I used this solution:
Yes looks like they may revert it. Let’s see what happens with this PR
