Update Log
I have seen many people posting about problems during an update. Many times the problems are due to not waiting long enough on the rpi to reboot / update / etc. Since we are using beta software, failures happen and I think an answer to this would be helpful to many people - Is there something in the ha su log or ha core log or maybe somewhere else that people can follow that at x point the update, reboot, etc is done and the system should be able to load? If it doesn’t after this point than user intervention is needed. For example, there has been 4 rapid updates to .107. Two worked for as they should. System updated and lovelace loaded. Two did not load. I needed to do a ha host reboot from ssh to get Lovelace to load. I never know looking at the logs when it is done updating or if there is a problem.
I too would like to know how to track progress of a core update as mine is currently failing and don’t know how to fix it. Nothing obvious in the system logs
