Update multiple entities in one API call?
Ref rest api.
If I have two entities i want to update with the API, can I do this in just ONE api call, or do I have to make two calls?
example:
I want to set light.outside to on
and also set light.inside to off
Is it possible? If so how should the JSON be formated?
No, not that Iā€™m aware of, because this would generally require two services: light/turn_on and light/turn_off. Unless it just so happens that light.outside is off and light.inside is on at the time, then you could do it with light/toggle. :wink:
thanks :slight_smile: .
What if same service are used with different entities and values?
example:
I want to set light.outside to on with brightness: 100
and also set light.inside to on with brightness: 200
Still no. Basically, you can only do with the service allows. For turning on a light, see Service light.turn_on.
okey then :slight_smile: thanks
