I have HA on a RPi4, it’s been working without issues for a couple of years since I last resintalled everything, but lately it’s been acting up.
I have two updates (HA Core 2024.4.2 => 2024.4.2 and HA OS 12.1 => 12.2) and when I update, it doesn’t seem to work. The machine will go away for a while, then when I can access it again, the updates are still available.
I have a zigbee2mqtt that I reload at regular schedule (to avoid issues with a specific device I’m using with it), but now sometimes when it reboots, I get an error:
Can’t create container from addon_45df7312_zigbee2mqtt: 409 Client Error for http+docker://localhost/v1.43/containers/create?name=addon_45df7312_zigbee2mqtt: Conflict (“Conflict. The container name “/addon_45df7312_zigbee2mqtt” is already in use by container “0037b5402a73cf7b5558a1a8463c92c6a8e6a1b02ea4542b5e9289a19b0278a3”. You have to remove (or rename) that container to be able to reuse that name.”)
I have all sorts of other errors in the logs that don’t look good:
- Failed to to call /host/info -
- Failed to to call /backups -
- Failed to to call /addons -
Unrecoverable sqlite3 database corruption detected: (sqlite3.DatabaseError) database disk image is malformed [SQL: SELECT anon_1.metadata_id, anon_1.state, anon_1.last_updated_ts, anon_1.last_changed_ts, anon_1.attributes FROM (SELECT anon_2.metadata_id AS metadata_id, anon_2.state AS state, anon_2.last_updated_ts AS last_updated_ts, anon_2.last_changed_ts AS last_changed_ts, anon_2.attributes AS attributes FROM (SELECT states.metadata_id AS metadata_id, states.state AS state, ? AS last_updated_ts, ? AS last_changed_ts, CASE WHEN (state_attributes.shared_attrs IS NULL) THEN states.attributes ELSE state_attributes.shared_attrs END AS attributes FROM states JOIN (SELECT states.metadata_id AS max_metadata_id, max(states.last_updated_ts) AS max_last_updated FROM states WHERE states.last_updated_ts >= ? AND states.last_updated_ts < ? AND states.metadata_id IN (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?) GROUP BY states.metadata_id) AS anon_3 ON states.metadata_id = anon_3.max_metadata_id AND states.last_updated_ts = anon_3.max_last_updated LEFT OUTER JOIN state_attributes ON states.attributes_id = state_attributes.attributes_id WHERE states.last_updated_ts >= ? AND states.last_updated_ts < ? AND states.metadata_id IN (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)) AS anon_2 UNION ALL SELECT anon_4.metadata_id AS metadata_id, anon_4.state AS state, anon_4.last_updated_ts AS last_updated_ts, anon_4.last_changed_ts AS last_changed_ts, anon_4.attributes AS attributes FROM (SELECT states.metadata_id AS metadata_id, states.state AS state, states.last_updated_ts AS last_updated_ts, states.last_changed_ts AS last_changed_ts, CASE WHEN (state_attributes.shared_attrs IS NULL) THEN states.attributes ELSE state_attributes.shared_attrs END AS attributes FROM states LEFT OUTER JOIN state_attributes ON states.attributes_id = state_attributes.attributes_id WHERE states.metadata_id IN (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?) AND states.last_updated_ts > ? AND states.last_updated_ts < ?) AS anon_4) AS anon_1 ORDER BY anon_1.metadata_id, anon_1.last_updated_ts] [parameters: (0, 0, 1713131334.899448, 1713147899.999999, 3415, 3414, 3514, 3602, 3603, 5438, 5439, 1186, 1187, 1188, 1189, 1219, 1220, 1221, 1222, 1178, 1947, 1180, 1181, 3194, 3195, 3196, 3197, 1195, 1196, 1197, 1198, 1170, 1171, 1172, 1173, 1203, 1204, 1205, 1206, 1089, 1090, 1091, 1092, 1211, 1212, 1213, 1214, 1097, 1098, 1099 … 241 parameters truncated … 3606, 3607, 3208, 3209, 3210, 3211, 3213, 3242, 3243, 3244, 3215, 3245, 3246, 3247, 3217, 3219, 3221, 3223, 3225, 3227, 3229, 3231, 3233, 3235, 3237, 3239, 3241, 3254, 3255, 3256, 3257, 3259, 3260, 3261, 3262, 3264, 3265, 3266, 3267, 5695, 3270, 5733, 5734, 5735, 5736, 5737, 5738, 5739, 1713147899.999999, 1713148200.0)] (Background on this error at: Error Messages — SQLAlchemy 2.0 Documentation)
Any idea what to do to diagnose and/or fix ?
EDIT: 100% sure my sd card is done, now. I tried reinstalling HA to it, and the verification at the end failed, saying what’s on it is different from what was written.
