Update notifications (Core, OS, Addons, HACS, etc)
Any updates on this?
Currently i cant save it, no matter i i choose the mobile two times or one once.
The error is:
Automatisierung ist nicht verfügbar
Message malformed: extra keys not allowed @ data['neueste']
I followed the suggestion here and removed the 2nd entry for mobile device to work around the issue.
Thanks a lot, that finally works around the issue, without specify two devices.
Hope that get’s fixed in the official blueprint sometime.
pOpY
Thanks for this amazing blueprint! I’ve just installed it but i can’t configure it because my device list is empty?
While both my iphone and ipad are available in the total device list?
Hopefully someone can help me out.
Update: i’ve removed both my mobile devices from the mobile app integration and reinstalled the home assistant app on both devices, this fixed the problem.
Is this blueprint still a viable option or is there something else more up to date?
This Blueprint hasn’t been updated since 2022
Still works for me!
I just installed and it works. There is an initial issue where I had to put the same mobile device under ‘Mobile app device’ and ‘Mobile app device 2’
A modified version (just one mobile device) still works here. I can provide it, when needed.
Anyway to adopt this for the repairs count as a notification?
Hey @pOpY , please, do upload it, if you can. Thanks!
Here it is:
blueprint:
  name: Update notifications
  description: Send notifications for new updates and install or skip on action
  homeassistant:
    min_version: 2022.4.0
  domain: automation
  input:
    update_entities:
      description:
        List of update entities to watch for updates on and be notified
        as soon as one is available.
      selector:
        entity:
          domain:
            - update
          multiple: true
    mobile_app_device:
      name: Device to notify
      description: Device needs to run the official Home Assistant app to receive notifications.
      selector:
        device:
          integration: mobile_app
    send_to_ha:
      name: Send to HA
      description: Send to HA as a persistent notification
      default: false
      selector:
        boolean: {}
    reminder_hours:
      description:
        "If provided, will send reminders for pending updates every x hours.
        NOTE: This will remind you about any pending updates every x hours, not just
        the ones listed in `update_entities`. So even if you dont list every update
        entity there you can still get notified pretty soon after an update."
      default: "3"
      selector:
        select:
          options:
            - None
            - "1"
            - "2"
            - "3"
            - "6"
            - "12"
            - "24"
          multiple: false
          custom_value: false
    take_backup:
      description: Do a partial backup before updating if able
      default: true
      selector:
        boolean: {}
    run_config_check:
      name: Run config check
      description:
        "If true, this automation will start the `check configuration`
        addon when a core update is available. The notification will initially say
        config check is running and then update when it completes. Clicking the notification
        will open that addon's logs so you can check the status. WARNING: You must
        list your update entity for core in `update_entities` to use this feature."
      default: false
      selector:
        boolean: {}
    changelog_urls:
      description:
        "Some update entities (ex. the ones for addons) don't have a link
        to the changelog because they can't. If this bothers you then you can provide
        a dictionary here. Each key should be an update entity ID and the value the
        url to its changelog. This will only be used if `release_url` is `null` on
        the update entity. EX. `update.adguard_home_update: https://github.com/hassio-addons/addon-adguard-home/releases/latest`
        or `update.mariadb_update: https://github.com/home-assistant/addons/blob/73b8524adb7bea195a6d45790a32ebe0081d2ea4/mariadb/CHANGELOG.md`"
      default: none
      selector:
        object: {}
    only_after:
      description: Only send notifications to mobile devices after this time
      default: 00:00:00
      selector:
        time: {}
    only_before:
      description: Only send notifications to mobile devices before this time
      default: 00:00:00
      selector:
        time: {}
    notification_channel:
      description:
        Sets the [channel](https://companion.home-assistant.io/docs/notifications/notifications-basic#notification-channels)
        (android) and [group](https://companion.home-assistant.io/docs/notifications/notifications-basic#grouping)
        (ios) for update notifications
      default: Updates
      selector:
        text: {}
    status_bar_icon:
      name: Status bar icon
      description:
        "(Android only) Sets the [status bar icon](https://companion.home-assistant.io/docs/notifications/notifications-basic/#notification-icon).
        NOTE: Different then the icon inside the notification, that is always set
        to the entity picture of the update entity (if it has one)."
      default: mdi:package-up
      selector:
        icon:
          placeholder: mdi:package-up
  source_url: https://gist.github.com/mdegat01/13d91bc293e8b98cba2c9ee932527dea
mode: parallel
max: 100
trigger_variables:
  _reminder_hours: !input reminder_hours
  reminder_hours: "{{ _reminder_hours | default(0) | int(0) }}"
  run_config_check: !input run_config_check
  update_entities: !input update_entities
  - id: new
    platform: state
    entity_id: !input update_entities
    to: "on"
  - id: started
    platform: state
    attribute: in_progress
    to: true
  - id: done
    platform: state
    to: "off"
  - id: install
    platform: event
    event_type: mobile_app_notification_action
    event_data:
      action: install-update
  - id: install_ios
    platform: event
    event_data:
      actionName: install-update
  - id: skip
    platform: event
    event_data:
      action: skip-update
  - id: skip_ios
    platform: event
    event_data:
      actionName: skip-update
  - id: core_check
    platform: template
    value_template:
      "{% set ns = namespace(core=none) %} {% for u in integration_entities('hassio')
      | select('in', update_entities)\n        if (device_attr(u, 'identifiers') | first)[1]
      == 'core' %}\n    {% set ns.core = u %}\n{% endfor %} {% if run_config_check and
      ns.core is string and expand(ns.core) | first | attr('state') == 'on' %}\n  {%
      for e in expand(integration_entities('hassio')) | selectattr('attributes.device_class',
      'eq', 'running')\n        if (device_attr(e.entity_id, 'identifiers') | first)[1]
      == 'core_check_config' %}\n      {{ e.state == 'off' and e.last_changed > expand(ns.core)
      | first | attr('last_changed') }}\n  {% endfor %}\n{% else %}\n  {{ false }}\n{%
      endif %}"
  - id: ha_start
    platform: homeassistant
    event: start
    value_template:
      "{{ states.update | selectattr('state', 'eq', 'on') | list | count
      > 0\n  and reminder_hours > 0 and now().hour % reminder_hours == 0\n  and now().minute
      == 0 and now().second == 0 }}"
  - id: sticky_ios
    platform: event
    event_data:
      action: URI
variables:
  mobile_app_device: !input mobile_app_device
  send_to_ha: !input send_to_ha
  _changelog_urls: !input changelog_urls
  changelog_urls: "{{ _changelog_urls if _changelog_urls is mapping else {} }}"
  take_backup: !input take_backup
  core_update_entity:
    "{% for u in integration_entities('hassio') | select('search',
    '^update[.]')\n        if (device_attr(u, 'identifiers') | first)[1] == 'core'
    %}\n    {{ u }}\n{% endfor %}"
  os_update_entity:
    '^update[.]')\n        if (device_attr(u, 'identifiers') | first)[1] == 'OS' %}\n
    \   {{ u }}\n{% endfor %}"
  skip_action:
    action: skip-update
    title: Skip
    destructive: true
    authenticationRequired: true
  update_action:
    title: Update
    destructive: true
  choose:
    - alias: Install update action
      conditions: "{{ trigger.id in ['install', 'install_ios'] }}"
      sequence:
        - variables:
            entity_id:
              "update.{{ trigger.event.data.tag\n  if trigger.event.data.tag
              is string and trigger.event.data.tag != ''\n  else trigger.event.data.action_data.tag
        - service: update.install
            entity_id: "{{ entity_id }}"
            backup:
              "{% set ids = device_attr(entity_id, 'identifiers') | first %} {{
              take_backup and ids[0] == 'hassio' and ids[1] not in ['supervisor',
              'OS'] }}"
    - alias: Skip update action
      conditions: "{{ trigger.id in ['skip', 'skip_ios'] }}"
      sequence:
        service: update.skip
          entity_id:
    - alias: Update completed
      conditions: "{{ trigger.id == 'done' }}"
      sequence:
        - &id004
          variables:
            entity_id: "{{ trigger.entity_id }}"
        - &id001
          variables:
            message: clear_notification
              tag: "{{ entity_id[7:] }}"
        - &id002
          choose: []
          default:
            - variables:
                data: "{{ dict(data, action_data={'tag': data.tag}) }}"
            - choose:
                alias: Send to first mobile device if specified
                conditions: "{{ not not mobile_app_device }}"
                sequence:
                  device_id: !input mobile_app_device
                  domain: mobile_app
                  type: notify
                  title: "{{ title | default('') }}"
                  message:
                    "{{ message if device_attr(mobile_app_device, 'manufacturer')
                    != 'Apple'\n    else message | replace('<br>', '\\n') }}"
                    "{{ data if\n      device_attr(mobile_app_device, 'manufacturer')
                    != 'Apple' or data.icon_url is not string\n    else dict(data, image=data.icon_url)
        - &id003
          alias: Dismiss from HA if replicating there
          choose:
            conditions: "{{ send_to_ha }}"
            sequence:
              service: persistent_notification.dismiss
                notification_id: "{{ entity_id[7:] }}"
    - alias: On startup, dismiss core and os notifications as they occurred while off
      conditions: "{{ trigger.id == 'ha_start' }}"
      sequence:
        - alias: Dismiss core update notification if off
          choose:
            conditions:
              "{{ core_update_entity != '' and expand(core_update_entity)
              | first | attr('state') == 'off' }}"
            sequence:
              - variables:
                  entity_id: "{{ core_update_entity }}"
              - *id001
              - *id002
              - *id003
        - alias: Dismiss os update notification if off
          choose:
            conditions:
              "{{ os_update_entity != '' and expand(os_update_entity) | first
            sequence:
              - variables:
                  entity_id: "{{ os_update_entity }}"
              - *id001
              - *id002
              - *id003
    - alias: New update available
      conditions: "{{ trigger.id == 'new' }}"
      sequence:
        - *id004
        - &id005
          variables:
            ids: "{{ device_attr(entity_id, 'identifiers') | first }}"
            changelog_action:
              action: URI
              title: Changelog
              uri:
                "{% set version = state_attr(entity_id, 'latest_version') %} {{ state_attr(entity_id,
                'release_url')\n    | default(changelog_urls[entity_id] | default(''),
                true)\n    | regex_replace('(/CHANGELOG.md)$', '\\\\1#' ~ version | regex_replace('[^-\\\\w]'))\n
                \   | default(None, true) }}"
            include_core_check:
              "{{ run_config_check and ids[0] == 'hassio' and ids[1]
              == 'core' }}"
            core_check_complete:
              | first)[1] == 'core' %}\n    {% set ns.core = u %}\n{% endfor %} {% if
              run_config_check and ns.core is string and expand(ns.core) | first | attr('state')
              == 'on' %}\n  {% for e in expand(integration_entities('hassio')) | selectattr('attributes.device_class',
              first)[1] == 'core_check_config' %}\n      {{ e.state == 'off' and e.last_changed
              > expand(ns.core) | first | attr('last_changed') }}\n  {% endfor %}\n{%
              else %}\n  {{ false }}\n{% endif %}"
            title: "{{ state_attr(entity_id, 'friendly_name') }}"
            message:
              "{% set summary = state_attr(entity_id, 'release_summary') %} Newest
              version is {{ state_attr(entity_id, 'latest_version') }}<br> Installed version
              is {{ state_attr(entity_id, 'installed_version') }} {% if include_core_check
              %}\n  <br>Config check has {{ 'completed, check addon logs for status.'\n
              \   if core_check_complete else 'started, should be done soon.' }}\n{% endif
              %} {{ '<br>' ~ summary if summary is string }}"
            url:
              "{% set url = device_attr(entity_id, 'configuration_url') %} {% set ids
              = device_attr(entity_id, 'identifiers') | first %} {% if url is string %}\n
              \ {{ url | regex_replace('^homeassistant://') }}\n{% elif ids[0] == 'hassio'
              and ids[1] in ['supervisor', 'OS'] %}\n  /hassio/system\n{% elif run_config_check
              and ids[0] == 'hassio' and ids[1] == 'core' %}\n  /hassio/addon/core_check_config/logs\n{%
              else %}\n  /config\n{% endif %}"
              channel: !input notification_channel
              group: !input notification_channel
              notification_icon: !input status_bar_icon
              icon_url:
                "{{ state_attr(entity_id, 'entity_picture') | default('',
                true) }}"
              url: "{{ url }}"
              clickAction: "{{ url }}"
              sticky: "true"
              actions:
                "{{ ([changelog_action] if changelog_action.uri is string else
                []) + [update_action] +\n  ([] if ids[0] == 'hassio' and ids[1] == 'supervisor'
                else [skip_action]) }}"
        - &id007
          choose:
            alias: Only send to mobile devices if within provided time range
            conditions:
              condition: time
              after: !input only_after
              before: !input only_before
            sequence: *id002
        - &id006
          alias: Send to HA if replicating there
          choose:
            sequence:
              service: persistent_notification.create
                title: "{{ title }}"
                message:
                  "{{ '%s\\n\\n### More info\\n- [Open](%s)' % (message | replace('<br>',
                  '\\n'), data.url) ~\n  ('\\n- [Changelog](%s)' % changelog_action.uri
                  if changelog_action.uri is string else '') }}"
        - alias: Stop if this isn't core or we're not running a config check
          condition: "{{ include_core_check }}"
        - alias: Start config check addon
          service: hassio.addon_start
            addon: core_check_config
    - alias: Emulate sticky on IOS by recreating the notification
      conditions:
        - "{{ trigger.id == 'sticky_ios' }}"
        - "{{ trigger.event.data.action_data is mapping and trigger.event.data.action_data.tag
          is string }}"
        - "{{ is_state('update.' ~ trigger.event.data.action_data.tag, 'on') }}"
      sequence:
        - variables:
            entity_id:
        - *id005
        - *id002
        - *id006
    - alias: Core check addon completed
      conditions: "{{ trigger.id == 'core_check' }}"
      sequence:
        - variables:
        - *id005
        - *id007
        - *id006
    - alias: Update started
      conditions: "{{ trigger.id == 'started' }}"
      sequence:
        - *id004
        - *id005
        - variables:
            message: Updating...
              "{{ dict(data, actions=[changelog_action] if changelog_action.uri is
              string else []) }}"
        - *id007
        - *id006
    - alias: Send reminders if enabled
      conditions: "{{ reminder_hours > 0 }}"
      sequence:
        - alias: Get all pending, unstarted updates
          variables:
            updates:
              "{{ states.update\n    | selectattr('state', 'eq', 'on')\n    | rejectattr('attributes.in_progress',
              'true')\n    | map(attribute='entity_id') | list }}"
        - alias: Loop over updates and send reminder
          repeat:
            count: "{{ updates | count }}"
            sequence:
              - variables:
                  entity_id: "{{ updates[repeat.index - 1] }}"
              - *id005
              - *id007
              - *id006
Thank you!
You’re welcome.
My apologies if this is to far off topic and should be posted elsewhere. Just let me know,
I have been having issues with a loooong installed blueprint (Update notifications) including recent log errors, so after researching blueprints learned (I beleve) that a blueprint is a STATIC import from GIST w/o any version info (yes I looked at some automation that are looking at ways to automate their updates butt DO NOT want to muddy the water by going down that path for the moment.
Anyways back to the issue(s). Given the static nature prevailing wisdom seems to. be simple reimport the BP, and assuming the inputs don’t vary significantly between when you ORIGINALLY imported (and created the automation(s) that use the BP), your automations should pick up any changes that were published two Github… This is my ASSUMPTION, PLEASE correct me if I am wrong…
Now on why any of this is relevant here… When I still had issues (including the need to double list my phone for notification as is well documented), I thought being a good former Engineer I would double check not just the mod date of blueprint I have locally but also the source. I diff’d my local copy (even updated again today), and compared it to Mike’s posted GIST and the two do not match ?!?
What am I missing in may understanding? Github says @CentralCommand updated GitHub 2 wks ago and I refreshed today. I can post the FULL text of my local copy stored in /blueprints/automation/mdegat01/update_notifications.yaml if that is helpful just didn’t want to spam the group. I can also discuss the logged error but again wan ted to do MY best to troubleshoot by making sure I have the CURRENT blueprint BEFORE asking for help :smile: It’s the engineer in me…
Thanks for any help insight.
@taw123 use my modified version here: Update notifications (Core, OS, Addons, HACS, etc) - #131 by pOpY
In this i have removed the second notification target, so the issue don’t pop’s up.
Yes, when you replace the blueprint and not much changed (like in mine), your automations jus works as before.
The modded version works without issues for me on HA Core 2024-06.
@pOpY do you have your own post with your blueprint, since this has been abandoned?
Did you manage to get this working? I’m very new to the platform and am struggling with some of these complexities - but would love to have email notifications when updates are available - so, if you could share an anonymised version of your code, that would be awesome.
Is there an updated blueprint? The HACS 2.0 update broke some linking in the notifications…
Hello, would it be possible to add other communication options? Since my HA runs locally and I don’t have it on the internet, the notifications don’t work via the app. With other blueprints, I can add pushover, for example, and get my messages through it.
Mine is also not on the internet directly. I am using wireguard on my router and wgtunnel android App for switching automatically wireguard on/off when I am away/home. So my HA is always reachable and notifications are coming through.
