Hello all,
I am trying to update a number helper called “Previous Temperature” from a trigger change.
I have an automation that looks like this (in YAML):
alias: AutoTempMath
description: ""
- platform: state
entity_id:
- sensor.main_temp_room1
condition: []
- service: input_number.set_value
data_template:
entity_id: input_number.previous_temperature
value: "{{states('trigger.main_temp_room1.from_state') }}"
mode: single
The trigger is working… but the number is not getting updated.
This entity automatically updates every 15 minutes, and ultimately what I am trying to do is show the difference between the previous value and the current value. If there is a different way to do this than setting the previous value to a number, then having a card that does math (subtracting the current from the previous to show the change).
I did some searching in the forums here, but other similar things are around energy and utilize a meter (which I don’t think will work in this example).
