Signify seems to have started using self-signed certificates for `https://otau.m…eethue.com`.
Unsure if this is a bug on their end or a new configuration they have adopted going forward.
Either way, currently OTA updates using images hosted on that URL will fail:
debug 2023-12-29 05:55:33: Received MQTT message on 'zigbee2mqtt/bridge/request/device/ota_update/update' with data '{"id":"Bedroom Lamp","transaction":"r82z7-1"}'
info 2023-12-29 05:55:33: Updating 'Bedroom Lamp' to latest firmware
debug 2023-12-29 05:55:33: Received Zigbee message from 'Bedroom Lamp', type 'readResponse', cluster 'genBasic', data '{"dateCode":"20230606","swBuildId":"1.108.5"}' from endpoint 11 with groupID 0
info 2023-12-29 05:55:33: MQTT publish: topic 'zigbee2mqtt/Bedroom Lamp', payload '{"brightness":254,"color":{"h":32,"hue":32,"s":81,"saturation":81,"x":0.4574,"y":0.41},"color_mode":"color_temp","color_temp":366,"color_temp_startup":65535,"last_seen":"2023-12-29T10:55:33.511Z","linkquality":144,"power_on_behavior":"previous","state":"OFF","update":{"installed_version":16786946,"latest_version":16786948,"state":"available"},"update_available":null}'
debug 2023-12-29 05:55:33: Updating to latest '0x0017880103adfb62' (LCT016)
debug 2023-12-29 05:55:33: Using endpoint '11'
debug 2023-12-29 05:55:33: Received Zigbee message from 'Bedroom Lamp', type 'commandQueryNextImageRequest', cluster 'genOta', data '{"fieldControl":0,"fileVersion":16786946,"imageType":268,"manufacturerCode":4107}' from endpoint 11 with groupID 0
info 2023-12-29 05:55:33: MQTT publish: topic 'zigbee2mqtt/Bedroom Lamp', payload '{"brightness":254,"color":{"h":32,"hue":32,"s":81,"saturation":81,"x":0.4574,"y":0.41},"color_mode":"color_temp","color_temp":366,"color_temp_startup":65535,"last_seen":"2023-12-29T10:55:33.739Z","linkquality":144,"power_on_behavior":"previous","state":"OFF","update":{"installed_version":16786946,"latest_version":16786948,"state":"available"},"update_available":null}'
debug 2023-12-29 05:55:33: Got OTA request '{"fieldControl":0,"manufacturerCode":4107,"imageType":268,"fileVersion":16786946}'
debug 2023-12-29 05:55:33: ZigbeeOTA: downloaded main index
debug 2023-12-29 05:55:33: getNewImage for '0x0017880103adfb62', meta {"fileVersion":16786948,"fileSize":267324,"url":"https://otau.meethue.com/storage/ZGB_100B_010C/3a5dab1a-faf6-47a8-9c9a-34f34eec029f/100B-010C-01002604-ConfLight-Lamps_0012.zigbee","sha512":"e9371e1599b193730f5358cdc64671e93042de1ddf669a970c4e9ce76363bea0b7198838fa4584271b3f1586e4d92565a2cc28a90143889576bab6576ef0e2ce"}
debug 2023-12-29 05:55:33: ZigbeeOTA: downloading firmware image from https://otau.meethue.com/storage/ZGB_100B_010C/3a5dab1a-faf6-47a8-9c9a-34f34eec029f/100B-010C-01002604-ConfLight-Lamps_0012.zigbee
debug 2023-12-29 05:55:34: Update of 'Bedroom Lamp' failed (Error: self signed certificate in certificate chain)
info 2023-12-29 05:55:34: MQTT publish: topic 'zigbee2mqtt/Bedroom Lamp', payload '{"brightness":254,"color":{"h":32,"hue":32,"s":81,"saturation":81,"x":0.4574,"y":0.41},"color_mode":"color_temp","color_temp":366,"color_temp_startup":65535,"last_seen":"2023-12-29T10:55:33.739Z","linkquality":144,"power_on_behavior":"previous","state":"OFF","update":{"installed_version":16786946,"latest_version":16786948,"state":"available"},"update_available":null}'
info 2023-12-29 05:55:34: MQTT publish: topic 'zigbee2mqtt/bridge/response/device/ota_update/update', payload '{"data":{"id":"Bedroom Lamp"},"error":"Update of 'Bedroom Lamp' failed (self signed certificate in certificate chain)","status":"error","transaction":"r82z7-1"}'
error 2023-12-29 05:55:34: Update of 'Bedroom Lamp' failed (self signed certificate in certificate chain)
debug 2023-12-29 05:55:34: Error: self signed certificate in certificate chain
at Function.AxiosError.from (/app/node_modules/axios/lib/core/AxiosError.js:89:14)
at RedirectableRequest.handleRequestError (/app/node_modules/axios/lib/adapters/http.js:606:25)
at RedirectableRequest.emit (node:events:513:28)
at ClientRequest.eventHandlers.<computed> (/app/node_modules/follow-redirects/index.js:14:24)
at ClientRequest.emit (node:events:513:28)
at TLSSocket.socketErrorListener (node:_http_client:494:9)
at TLSSocket.emit (node:events:513:28)
at emitErrorNT (node:internal/streams/destroy:157:8)
at emitErrorCloseNT (node:internal/streams/destroy:122:3)
at processTicksAndRejections (node:internal/process/task_queues:83:21)
<details>
<summary>Certificate Chain</summary>
❯ openssl s_client -showcerts -connect otau.meethue.com:443
CONNECTED(00000003)
depth=2 C = NL, O = Philips Hue, CN = root
verify error:num=19:self-signed certificate in certificate chain
verify return:1
verify return:1
depth=1 C = NL, O = Philips Hue, CN = intermediate
verify return:1
depth=0 C = NL, O = Philips Hue, CN = otau.meethue.com
verify return:1
Certificate chain
0 s:C = NL, O = Philips Hue, CN = otau.meethue.com
i:C = NL, O = Philips Hue, CN = intermediate
a:PKEY: id-ecPublicKey, 256 (bit); sigalg: ecdsa-with-SHA256
v:NotBefore: Dec 28 08:19:26 2023 GMT; NotAfter: Dec 27 08:19:26 2024 GMT
-----BEGIN CERTIFICATE-----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=
-----END CERTIFICATE-----
1 s:C = NL, O = Philips Hue, CN = intermediate
i:C = NL, O = Philips Hue, CN = root
v:NotBefore: Sep 21 09:35:35 2021 GMT; NotAfter: Nov 10 09:35:35 2026 GMT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2 s:C = NL, O = Philips Hue, CN = root
v:NotBefore: Aug 25 07:59:43 2016 GMT; NotAfter: Jan 5 07:59:43 2068 GMT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Server certificate
subject=C = NL, O = Philips Hue, CN = otau.meethue.com
issuer=C = NL, O = Philips Hue, CN = intermediate
No client certificate CA names sent
Peer signing digest: SHA256
Peer signature type: ECDSA
Server Temp Key: X25519, 253 bits
SSL handshake has read 1795 bytes and written 400 bytes
Verification error: self-signed certificate in certificate chain
New, TLSv1.3, Cipher is TLS_AES_256_GCM_SHA384
Server public key is 256 bit
This TLS version forbids renegotiation.
Compression: NONE
Expansion: NONE
No ALPN negotiated
Early data was not sent
Verify return code: 19 (self-signed certificate in certificate chain)
</details>
Related: https://github.com/Koenkk/zigbee2mqtt/issues/20429
